Yeh, the wheels were borrowed from a friend while my TE37s were ebing stripped so we could re-paint them. They came up awesome, cant wait to get them on the car next week.
As for the rear wing, its rather hit and miss for me. I got it because i wanted a functional wing for track days. Was concerned many of the big aftermarket wings were more parachutes and drag adding then down force adding...so went with something that is obviously reasonable from the factory. I have a second boot lid that got painted up so it will be going on for street duties.
I see,
Yeah true about the R34 GTR wing... It's kinda like a GT Wing but a lot more subtle and still actually looks good.
LOL, this is the beauty of R32s. I always say silver looks the best. Then i see a mint black one and wish mine was black. Then i see white and wish mine was white. Then i see grey and think..... hell, i saw a maroon one the other day for sale that made me go "oooh-aaahhhhh"
Neat paint, neat wheels and low stance is all they need to look mint :D
I remember your 32 from GOR 3 years ago I was cruising with you for a while in my n/a POS auto 4 door 33 that looked like crap needless to say it ended up in a tree :ermm:
Your 4 door changed a lot over the years
Love yours Rekin, that colour and those wheels are a great combo.
Went to get in my car the other day and it just looked so pretty, I had to snap a couple of pics:
It may not look exactly like this next time, I'm getting it raised a bit since it's apparently too low (according to the po-lice). Apparently this will also help the handling (according to Racepace, not the po-lice).
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
