  • Replies 224
Posted Images
the kakimoto R33 (craig's that came 3rd in RWD) weren't running semi comps :) it was running 5 year old pirelli P-Zero that were hard as rock :D
BTW, me and darK have AWD cars :)
Great day guys. Very much fun was had.
Bris, where the thanks to your old man for looking after your jacket? :)
I really, really, need to get a damn handbrake, and some brakes, as it's killing me!!! No decent times for me.... :D
Bris, where the thanks to your old man for looking after your jacket? :D
You trying to rip the wheel out of your car when you had the kids in the back was gold. You warmed me up, then Miniwog finished me off, i was serisouly giddy after the run in the XR6.
Yeh, and thanks for looking out for the jacket...its worth some serious coin...but you suck for giving it back to me when it was actually warm...rather then at 4am when it was cold and i was wet and sleeping on the porch.
I think 335mm P-zeros would be pretty grippy :)
But my comment was based on both Tom's and Jarrod's results from the last DECA and this DECA.
Doing 360deg dougies dosn't help with times ;)
well done to everyone, everyone seems to be driving better and quicker each time these events are run, good stuff :D
the buleen bar sucked the wang and i couldnt work out why they were handing out bottle openers, i only saw today they had their logo on them.
the yahoo bar was tons better
I had a great weekend. Thanks to the organisers for running such a great event. I cant wait for the next one.
I wasnt expecting to do very well after seeing the times for the long wang, but it looks like i made up a bit of time on the skid-pan. Im happy with 10th.
Thanx to all the SAU guys for another fantastic weekend. Being a official or a competetor, dosen't matter!!! i still have a awesome time. Got to love the ride in the "taxi" on the skidpan :D
[opens photoshop]
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
