Cheers big ears... I like it too. Luckily so dose the missus.
The pictures don't really do it justice.
Your AR-X is just right too. I allready had the GTC's, otherwise I would have gone black on black with some R34 GTR rims.
Cheers
Justin
I'm with you....If it's not Black it's not awesome....pics are fine.
Edited by Jetwreck
OK......so last night I was looking at a picture of someone on Facebook planking......it was that pathetic I had to laugh.....what a loser!.....the I had a bright idea!!!....I need to start drinking again....this sober stuff makes me do silly things.
You are a strange man Mark Craigland, but I do have a question for you.
Whom is lamer, the planker or the person looking at plankers on facebook? :P
Finally got round to taking some photos of the Stag, since I don't think I've posted any up. I had cleaned it, and then got small flying insects all over the front of it...
And the AV setup that Brad did last weekend...
Stealth...ish...
That's very nice. I do so like them in white. Is that the tv tuner remote sensor on the a/c display? Also, you cant operate the a/c when the the double din screen is open :O. I suppose it's only open occasionally to no big deal. Brad did a great job on the AV install :thumbsup: .
That is the TV tuner remote sensor on the AC display. Right in the gap, works well :thumbsup:
I know what you mean with the screen, but I usually keep that screen closed so it doesn't bother me. That's why I was after a straight single DIN, but in the end the fold out screen video outputs to the factory screen so you don't even have to worry about the pop out.
ok so it's not MY stag, but still... You should recognize it.. and the ugly mug behind the wheel ;)
Can't you photoshop that sort of thing out?:nyaanyaa:
*edit* Forgot to complement you on the photo; love a close up, moving car shot!
Edited by Daleo
got a free photshoot done on the weekend by LukeTerbeekeMedia. thought i'd throw some shots
and my personal fav :thumbsup:
you can see them all here - plent more photos here -LTM
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
