Hey all, I am new to the SAU and would like to know if it is alright if i come out and say hello tonight as i am litle shy and would like to meet some of youse before the pizza night. :(:O:D
thank you all
SL33KY (Em)
thank you all
SL33KY (Em)
for sure no problem with that i should be out as well around 9pm...
I showed up last night around 10 to find a few silver skylines R33's and R32's I think they were, but I didn't stick around long enough to find out seeing as I was snubbed!!! Thanks guys!! :D
Apologies for theyre rudeness, who ever they were. It would be unlikely to be any of the regular SAU crew on here :D , at least the folk I know personally.
If it was some ppls off this forum - get some manners!!!
Edited after reading follow-on posts:
Who snubbed who, doesn't matter - seems a miss_take :dry:
-> Communication is a two way street <-
Edited by Sinista32
I showed up last night around 10 to find a few silver skylines R33's and R32's I think they were, but I didn't stick around long enough to find out seeing as I was snubbed!!! Thanks guys!! :)
SNUBBED?!?!?!
you didn't even get out of the car! we can't talk to you and say hi if you stay in your car!!! we thought you snubbed us!!! we dont prepare an official welcoming party for anyone...
next time, jump out of the car and come say hi. seriously, we wont be rude or anything, ok? promise... :mad:
i wasent there so i cant comment but i am guessing Frink, Blueprint, Bullet32 and a few others were there. They would probably have to be the nicest people in SAU canberra always up for a chat and attend most of the meetups we have eg Jerra and Museum. If you come out again make sure you say Hi as others have said we are all a friendly bunch of people.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
