Hi Marko,
1) The Nismo Kill Switch Cosmetic Lighter is a display item - but genuine Nismo
There's a recent WtB thread of how someone wanted one and an SAU Trader said he still had some left, even though they're discontinued.
Even the "Nismo" logo is the old type. Matthew (God_speed) noticed (since his eyes are better than mine), that there's a "Nissan" stamp on the collar too supposedly to make counterfeiting more difficult.
2) Steve-0 (N1GTR) mentioned to me that the "N1" sticker existed, so I sourced high and low.
It's the same font and brushed aluminium background as the "V-Spec" sticker on the rear quarter of the R34 GT-Rs.
Yes, there are many other differences on the R34 GT-R N1 too.
About 22x
Should I list them off?
More importantly you got to keep the flare, ha. It would be interesting to find out what options were available . I have a different front bar , orange indicators and no bagdes except for the usual GTR ones on the body. Also with all the log book and service stuff I got a pink safety driver sticker, ha, ha
Characteristics incl Specs of R34 GT-R N1 include...
1) N1 Engine Block
2) N1 Oil Pump
3) N1 Turbochargers
4) N1 Water Pump
5) Different Horns
6) No Air Conditioner
7) No Sound System - Just a Plastic Panel
8) No Speakers - Just Taped Over Cavities
9) No Driver's Door remote Control Opener or Motor
10) No Folding Rear Vision Mirror Control Button or Motor
11) Rear Vion Mirror housings Painted Black
12) Thin White (QM1) Body Paint down to 90 microns
13) Plastic Centre Console Lid
14) Plastic Handbrake Handle
15) No Cosmetic Mirror Behind Sun Visor
16) Thin Window Glass
17) No Privacy Glass
18) No Space Saver Wheel
19) No Rear Wiper Control or Motor or Blade
20) Rear Window With No Accommodating Hole for Wiper
21) No Rear Fog Light
22) Extra Reversing Light
23) Door Entry/Exit Lights Removed But Lenses Remain
24) Extra Large Oil Cooler and Piping (edit by kimbod)
25) Larger Rear Brake Discs (edit by kimbod)
26) No Clear Coat on Body Paint (edit by kimbod)
Not sure if this is the correct place for this post (I'm a newbie) but my GTS2 was stolen this morning from Ascot Vale Rd, Melbourne. Build #112. Been in the family since new and I'm absolutely gutted to see it stolen, please keep an eye out!
  • 3 weeks later...
Hey Yall
Is there a way of telling a BNR32 Vspec 1 to a Vspec 2 by the engine tags. Have been told that a Vspec 2 on a 32 will be something like this BNR32XXX-XXX8......if there is no 8, it is a Vspec1. If someone can confirm this it would be great.
Cheers
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
