env33d whats wheels/suspension are u running?
TEIN superstreet coilovers at their lowest setting, sitting on Apec Apaches, 18x8 all round. the apaches are copies of some other wheel i think, but they do their job
Here's a shot of my GTST. I'm kinda meh about it at the moment. Considering lower + bigger wheels.
Car looks really clean. Maybe lower it a bit more. I don't mind the wheels. They do look a touch small but the color and style of them looks really good on the white.
what size are those rims dude? imo it looks fine... like above, they look a littttle bit small and if it was lower just a tad it would look really nice.
@Basti: I want to do the opposite to you haha, I wanna possibly get rid of my GTR wing and put the std one on... but like you, my opinion changes all the time haha
A few new shots courtesy of Jarrod from JRM photography...
Thanks Jarrod!!!!!! ;)
Just told my wife this is what every BCNR33 should look like cough cough can i make mine look as clean as this? :D
She agreed we could of ate our dinner off this tonight !!! :)
Here's my beastie. Owned it since the 25th of may 07'. Its not the sexiest or cleanest car in the land, but its all my own work - to my taste. Not my dream car, But its what I could/can afford to build up.
hey mate, what rims are these?
to me they look like those 'dtm' things you get off ebay, but painted gunmetal? is that right? they look seriously hot!
mate got any more info on the sideskirt addons you have? they look awesome. better pics available?
basti are u trying to be all cryptic about asking for more specs on the chick in the photo? haha
Lol both can be arranged. Ill post up some pics when i get home. The carbon add ons are made by Vertex.
Edited by PM-R33
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
