It feels a bit more solid, bit more planted on the road than the 33. It's very snappy on the throttle too. It turns heads more often tha the R33 in my opinion. Overall its a refined car and is a great daily for me.
Mods wise, it's just got a rear muffler. coil overs, and bigger/wider wheels.
It's done 85 000 genuine km's and the interior is absolutely immaculate.
It's just amazing to drive and I cant wait to start doing modifications. I'd love to take it to Test N Tunes and just get it out for cuirses and shit.
It has slight hail damage on the bonnet but im not bothered as I can do that myself.
what did it run? how many kws etc?
Well on that run the car was on a basic street tune and did a 14.44 at 98mph. Went to the dyno last saturday and on the first pull it made 175rwkw, so I ran that time with this much power.
Finally the car made 302rwkw at 18 psi dropping to 17 psi. Gonna go to the drags this saturday to test it again and see how it goes and this time on ET street radials.
Edited by Girorostar
will be interesting to see how it goes! let us know mate.
Mine will be making it down to the drags in a few months! Been a long time coming!
10714429_10154749602830215_7273089594912
11001083_10205027243912924_589725379_o_z
10451688_10154721713615215_2799189075092
  • Like 1
Will do sir! I'm hoping for a low 12 to high 11. But because this is a street legal event the strip won't have traction compound so I'm hoping for the best.
Good luck with your car too, sir. 350 kw should get you some impressive times!
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
