Hi
My car has been above 250kws with the stock trans (+ shift kit and trans cooler) for 18 months running a PFC and has worked very well. The last 6 months it's been above 300 kws . In the interest of getting a high stall, i got Mike at MV auto's to strip my stock trans and do the full rebuild / high stall job. this includes all new larger bands etc.
Now for all the non believers out there that say the PFC wont shift correctly etc. wheres your proof?
When Mike disassembled my stock trans he found that everything inside was in great nick and was all well within specs.
So what other proof does anyone need that the PFC wont harm a S1 auto trans.
i have also installed a set of poncams and backed the boost off to 21psi for smack on 300kws but massive amounts of torque and with the gt3582r-iw im getting 7psi by 3000rpm "Go the auto"
cheers
darren
  • 1 month later...
Well at a recent drag meet put on by another car forum I have done a PB for the 1/4 mile.
11.08 @ 118mph
Im stoked with this time and now i want a 10 before i get rid of the Nissan engine management. I was able to leave the line with 13psi.
Cheers
Steve
RB25+HKS 2535
R33 GTS-t Auto + MV Shift Kit
450 cc Injectors, HKS 256/264 Cams, Wolf3D, etc.
Best ET [email protected] with balding 205 tyres,
this turbo can get you mid 12s with the right suspension and tyres
Editted first post PLUS
Same car, except RB30+HKS 3037 Pro S
435.1rwHp @ 21 psi
[email protected]
With overdrive OFF, it was hitting the rev limitter at top of 3rd Gear
with overdrive ON reached 121.45Mph
'95 R33 GTS-T Auto
PFC
Tomei 740cc injectors
Slide max oversize RB25 turbo
turbo-back exhaust
Walbro pump
Splitfires
FMIC
PRofec B spec-II
Z32 AFM
Adj cam gear
229rwkw at Racepace yesterday however it made 245rwkw but wasn't happy, too much knock. Needs a bigger housing on the turbo according to Ben.
Edited by DivHunter
  • 5 weeks later...
  • 3 months later...
I know i don't have a Skyline, but i do have a Automatic toyota Chaser. It is making 230rwkw on 15psi and i finally ran mine the other night and got a 12.95@110 mph. My 2.134 60fts were ok but my single spinner diff is holding me back. I'll get the diff done, and get some street slicks, and see if i can get that 60ft down to something respectable. With say a 1.9 60ft time and the speed i'm trapping at now, that should put me into mid to low 12's. Not too bad for a daily driver :P
  • 4 weeks later...
i'll add mine. 1995 r33 gtst
with a highflow panel it pulled 145.8 rwkw at RE Customs. the green line is the constant 7 psi boost and the red is factory. she's running fairly rich
the car has now got a trust PE2 catback and will have a full zorst and bleed valve in a few weeks. also will be adding a trans cooler soon and a shift kit later down the track. i'll post up another dyno run when the stuff goes on
184.5rwkw (248rwhp) @11psi with
FMIC
Turbo back 3" exhuast
Hi Flow Cat
Pod Filter ( :( )
22 dollar ebay boost controller
SAFCII
Custom Intercooler pipe kit (swapped the piping over from the usual set up)
Have a stage 2 shift kit, ordering 2800-3000 torque convertor on tuesday.
Then next year i get serious, new turbo, rebuild etc
Chris
  • 3 months later...
Hey Guys , anyone got any new updates ? I ended up hurting the auto (so i though, made noise as you load it up etc during a circuit sprint) , but it turned out to actually be the bloddy hiflow turbo..... of course i figured that one out AFTER i spent over 3K getting Mike doing the toughen up on the auto. Went up to a 3500 stall too. box wasn't to far before it was toast anyway.
Then spent 2.5K on a custom Turbonetics BB to fit into the vg30 rear housing.
Its been 3 months and i've been so busy i haven't had a chance to retune it to suit new turbo..... so thats on its way.... hope to get over the 260 rwkw we made previously. Will let you know how i go soon.
Any of the couple of guys on here at the top had experience with how much you can flow thru a vg30 housing ? and or the std log manifold... anyone had one extrude honed/power ported ?
Gary
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
