  • Replies 173
Posted Images
you sure? i was just counting in my head, but i call it 10. oh well.
for me it's.
kink = 1
left hander to go under the bridge = 2
right hander = 3
right hander with massive dip = 4
over the bridge = 5
right hand of the S = 6
left hander = 7
left hander = 8
flip flop i guess you could say is 2 turns not 1, so that = 9,10
and then left hander on to the straight, (pictured) = 10 or 11 depending on your point of view. I dunno how you get to 12 though.
OMG somthing magic happend. I am wrong. appologies. apparently some people call the right hander with the big dip 4, and the exit up it up the hill to the bridge 5. then the brige exit 6. sorry, right you are. turn 12 is the last turn. :yes:
yes, I dont see much wrong with that line. Turn 10 has a late apex.
w00t i have someone on my side!!! :laugh:
yeh i love that last corner, late braking and just plant it in hoping u dont drift too wide and scrap the wall lol
Apparantly my car wasn't at oran park. Noone seems to have any photo's of it at all. Not even power play :O
Yeah we do of it parked and pretty sure on the track aswell :laugh:
See what andrew can find tonite and send you some if you like!
I know this is you...
zomg and again
see plenty, there is still a few more of you on here http://s40.photobucket.com/albums/e236/alt...%20Day/?start=0 i snapped up every pic of you from page 14 onwards...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
