Hey Guys,
Before I start hitting tracks on a regualr basis I would just to have some sort of timing solution, which is better than bringing a friend with a stop watch or mounting a stowatch on your dash. Are there any purpose built stand alone solutions there for this??
I've seen this timer made by some italian company which fits in the centre of teh steering wheel which i think is cool...but it doesnt have a lap memory so it's only usefull for 1 hot lap. I guess what I'm after is a cheap, purpose built timer with a memory for lap times so I can stack up individual lap times, that can be easily secured to the car and easily pressed whilst going WOT down pass the start/finish line.
Any ideas?
https://www.sau.com.au/forums/topic/137530-in-car-timing-solutions/
  • Replies 41
I have a 32 lap timer from Speedwerx, but I'm not sure if they sell them anymore as they are not on their website. Speedwerx
Revolution Racegear has a steering wheel that has a built in laptimer that is triggered manually.
UAS are selling in car timing cheap about $300 from memory.
I paid over $600 for my intercomp and I am unhappy with how it works....it either misses laps or triggers mid lap. The sensitivity is adjustable but it takes a lot of stuffing around
Yeh the AiM units are very good. Im very happy with my Data Logger. More info then i know what to do with. The AiM lap timer has plenty of cool features...and from what i have seen the price that UAS sells them for...hard to go past
Actually, here it is http://www.aimrace.com.au/tgitaly1.htm
I did hear around 6 months ago there were a few bugs with them. But probably ironed out by now...if not a software upgrade for them will sort it out when they sort it out.
If you've got a palm pda sitting around you could give this a try.
http://handheld.softpedia.com/get/Business...mer-12090.shtml
Is there one for the Window base PDA?
I've been using the AIM as well and it's very user friendly. My mate has been bugging me to sell it to him :O Has anyone got a link to the UAS website? For 300 buck brand new, he should get it from them LOL
Um, sorry Baron - how much is it?
aimsports timer is ~$300. the driftbox judging from their site is around $1500. maybe a bit less but surely more than $1200 considering it's 465 squid + shipping to aus (unless someone is retailling them here).
Um, JDM imports do them. They have them listed for $1300, so you are pretty close with the estimate.
I thought I saw the Mychron TG timer on the back page of the Motorsport NSW mag for $449.
So the simple lap time is much cheaper. On the other hand the driftbox tells you lateral & longitudinal gees, speed, drift angle, track position & some other handy features. Unfortunately it doesn't log rpm which is a bit of a silly omission. That lot will tell you much more than just a straight lap time or even a sectored lap time. :(
yeah true true. Even at $449 i think the aim mychron timer is pretty good value. but not as much info as the driftbox, but i'd have nfi what to do with half of it! I just want reliable laptimes. :(
I'm selling my current lap timer as I am upgrading to a full dash with inbuilt timing. It's a Kartronic LT32 unit, this stores 32 times.
It comes with the Reciever and IR beacon.
$200
I'm in Yarra Glen, Victoria.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
