Ive got a link G4 sitting in a box waiting to go in :)
Was just looking for the stock ECU brackets because I think mine have disappeared off the ECU. Think I tried to fit them to the power fc but didnt work so they got seperated. Not to sure. Was going to pick some up from a guy but I was busy then txt him a few days later and havent heard back
Ive been doing some wiring the last 2 days. The results of wiring gauges etc in at different stages meant there was alot of messy shit everywhere. I used a crimp joiner to put my wideband gauge in without even bothering to fuse it so now ive fixed all that. Just need to find a constant power for my oil pressure gauge and connect it up then it will pretty much be right
We've made up some pipes for the coolant so we can tee off to the turbo and wastegate then tee it back together in the return. Not sure how necessary it is to water cool the tial gate but at leasti should never have to worry about it
Had thought about painting the intercooler pipes silver. Think it would look heaps better. But im getting to close to engine in that I dont think I can be bothered.
are you chsing the bracket for the ecu cal. ive got a spare at home
yeah ill send a pic to you.
Thanks for the pic yesterday man
Turns out that when I put the Power FC in, I tried to use the stock brackets on the Power FC, but when that didnt work I bolted them into the car and have been sitting the Power FC in the brackets since then.
Bit of a silly one that one lol........
Pretty much done all the wiring bar the MAP sensor and wiring the wideband into the link now. So just about ready to chuck the dash back in. Dad's going to clean up the rest of the bay for me while I'm at work so next week when I get back it should be engine in time.... Finally :)
I should really start a build thread......
Sorted the brackets out for the ECU, turns out my Power FC was in the opposite way to the standard one, but it worked
Got most of the dash back together, just gotta finish wiring up the launch control switch
Spliced the Analog out wire from my wideband into the ECU today, Hate cutting wires at the ECU plug lol.... Hopefully it works a treat
Get off night shift and decide to build brackets. Only problem is I started out wanting to build an oiler cooler bracket.
Doubt this will ever break. My MAP sensors used to be held to the throttle cable bracket with zip ties, so this is a bit nicer :P
This thread is my build thread now to BTW.......
Bens to busy playing with Toyotas lately :P
Nah ill do a build thread when its done probably. Still trying to sell my turbo kit to. If anyone here wants it or has a mate that wants it then ill do a deal. I have $1200 on it atm
Dont want to have to post it if I can help it
I want to bring it down to Bris, but will be a while before that will happen. Have to do alot of testing and let the thing run for a bit
Be a shame if it blew up, let alone half-way to Brisbane lol
Oil Pressure gauge installed. Have run out of room on the A-Pillar, and seen as I wont be looking at it as much It's mounted low. Dash has also been freshly painted. Its a bit of a lighter silver, more of a metallic grey, Bit nicer then full silver although it looks pretty silver in the photo:
And a shot of the engine with the Pressure test gear on. Pressure tested the coolant side of things, Dad found a leak in the rear block welsch plug, so that would have been a real pain (gearbox out) job to fix. All good now anyway. Let the thing sit with 1bar pressure in it for about 2 hours and next to no pressure drop and no leaks visable.
Off to do more engine bay prep today. Might have to check the intake side of things with a pressure tester if I can make one up to fit
Edited by 89CAL
Finally got around to making an oil cooler bracket, Turned out alright using a stock bracket off the car (still not sure what it was actually doing on there though)
And started prepping the engine bay. Spend some more time on the bay today and hopefully engine can go in sometime before I go back to work next week
Engine bay done. Could have spent more time and done the lot but don't have the time anymore. Need to get the thing done. Clutch off to get a rebuild. Its still in great condition. No hot spots or signs of damage. Just worn the material down. NPC (Y)
Posted Image
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
