How different would the results really be from an Rb25?? I'm going to be playing with an RB25DET Neo Powered R32 GTS4 soon, will be getting either a GT3076R, GTX3076R or T67-25G ... depending on where the owner goes with that. I'm quite interested to see how that goes.
blast from the past. I never did it but the idea still hangs with me. I might do it one day. thinking about a small-ish borg warner EFR TS/twin gate set-up. could be nice.
since this thread I built my GTR with GTSS, another one with 2530s, and yet another one with 2530s so still rocking twins. current GTR is jun 2.7 engine with 2530s but thinking about putting it onto E85 now and wind up the wick a bit.
Hey there,
New to the forum and wanted some advice on SST upgrade for R32 GTR.
Built motor (rods/pistons/cams/cam gears all the usual stuff)
Basically just looking for response (only 260 poncams)
What's your opinions on HKS 3037?
Cheers
Looking at the rb25 sticky, the hks 3037 is making 280-300kw, is that acceptable? A built rb26 is probably better than the rb25s in the sticky thread. There are established good response, better power twin low mounts, set ups well described. I like the simplicity of a single setup.
Edited by WHITE gtt
Hey Rich,
My GTR initially had an Apexi IHI RX-6 TCW77P25. Stock RB26 with a couple of cams. Little baby, could only make 400hp atw no matter how much boost I threw at it. left it on 19psi, super responsive, full boost well under 4k ran heaps of mid 11s at the drags. (ps if anyone wants it - it's sat in the garage at home with manifold, wastegate setup etc). Upgraded to a GT35R and overcame the tempation to go to the T04z and the like. Useable power > *
A new GTX3076 or whatever they are would be wicked.
Mick
still getting used to posting and such. Sorry about that.
Yeh 300kw would be acceptable. Just looking for a nice responsive thing that you don't have to wring its neck evrerywhere
Edited by Whiskey Ghost
  • 3 years later...
Hey guys, been doing some reading and found this old old post.
Can't find to much more on the subject.
I am currently setting up a small turbo on my r32 gtr, after putting n1 turbos on and hating them I decided I was never going through the twin turbo shit fight again, and I couldn't see why one turbo, wouldn't spool up better than two that are similar size combined, you have less mass to turn, in one turbo, and less bearings, less friction, maybe I'm wrong, but I couldn't find a straight answer anywhere so I decided I needed to do it myself.
I have a STD engine so won't be chasing big power, so I decided I would go for response instead, I have a very low budget and have done all the work myself.
The turbo I chose was a kinugawa tdo6sl2-20g ($1000)
This is t3, internally gated and has a 8cm rear housing. It came with all the gaskets and hoses I needed to fit it to the engine, didn't have to buy another thing in that area. Have heard alot about these turbos and really wanted to give one a go.
This is bolted to a ebay manifold ($350), and did some custom intake piping from some silicone joiners off eBay and some alloy pipe laying around at home ($50)
For the dump pipe, I used 3 inch flexible stainless truck exhaust ($60), down to the cat, this is welded onto a vband flange which came with the turbo
I know some of you would be cringing by now at this set up, but I'm into trying somthing Different.
I brought a second hand adaptronic e1280s off my mate for $500 and wired in a map sensor ($60)
The set up hasn't run yet, just in the final stages of setting up the adaptronic, I have heard of people making 300kw with these turbos on sr20s and rb25s, so I don't see why the 26 won't do it, and it should have very little lag which will make it awesome to drive and look after my STD engine, not having to rev it hard to get ssomewhere.
Or it might just not work... Haha we'll soon find out.
Let me know your thoughts guys
They were r34 gtr n1s
Were never dynoed, they would have been alot better if tuned properly and stuff but I just wanted single for the ease of working on the car.
The n1s got on boost at about 4-4500 which I was not stoked with.
I've done a number of tests based on small singles fitted to a unopened GTR engine. You can find more details on my thread.
Be brief. I've fitted one of my TD06SL205 Turbocharger on my GTR externally gated in 10cm rear. It runs off a TD06L2 turbine, with a compressor that is15% more efficient then a standard 20G without adding lag. This is a proven turbocharger working with SR20 and Rb25 engines.
On Rb26, because the head flows so well, the extra rev and engine capacity, this turbo can not keep up with set boost once the engines revs over 5000RPM. Stronger external gate spring only caused higher boost spike in mid range while made no changes up top. Been the Kando's standard TD06L2-20G, your boost tapper should be even worse.
Best power was 308awkws pump 98 fuel, Vs factory Twin T25s
On E85 the best run was 367awkws, and averaging of 350rwkws.
Goal was responsive 400awkws, data from the following evaluations shown that I could never get that. Lead me thinking twice of why Nissan have chosen to twin turbocharge this engine.
Anyway, I don't usually stop till I get there, so scraped every thing I knew about Rb25det and start fresh, many weeks of modeling, testing and $$$$$ later (Check details on my thread), it worked.
ATR45SAT / AKA ATR43G4/SAT. 411awkws @ 24psi, E85 Fuel
Power and Response Vs Stock T25s
This turbocharger has been left on my car since.
Ps. It doesn't cost much more then what you've paid. List your TD0620G back on Ebay and fit this instead.
  • Like 1
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
