post pics of the queer lancer kris
"who cares, you've owned a car faster than his will probably ever be, and you've obviously matured past the boy racer stage. he pretty much has no job now, so his car will be up for sale shortly" - Annon
Well after owning a 250rwkw car and going through EPA and all that bullshit ive decided to go for economy and a bit of a comfortable ride that wont get me police attention!
Here it is:
https://www.sau.com.au/forums/topic/140030-the-new-car/
  • Replies 43
Oooh - same wing as me :P
Lol yup! Even though it took them a day to put it on properly! Sif they havent done it b4!
Same everything.......oh sorry except for 4 wheel drive plus a few :( bits and pieces....lol
Not to mention the whole front looks different to the evo!
https://www.sau.com.au/forums/topic/140030-the-new-car/#findComment-2609752
lower, zorst... better rims... i will dig it moreso dude
it isnt actually as bad as i had first imagined when you told me. like.. it doesnt look all that gay. actually looks ok
them seats do look pretty comfy. swap the skyline seats for em lol
lmao @ anonymous. f**k your a queer c**t. go get mummy to pay for more mods big homie. emphasis on the big.
https://www.sau.com.au/forums/topic/140030-the-new-car/#findComment-2610720
hahaha
honestly why sell an R33 turbo to get a NA lancer if you're a performance car enthusiast?? listen to us all on SAU.. we all deal with the cops who hate modified cars. its something you deal with for the love of driving...
so are you a skyline or car enthusiast?
did you even have a choice in the matter or did you dad sell the R33 and buy this for you?
the R33 wasn't yours was it?
https://www.sau.com.au/forums/topic/140030-the-new-car/#findComment-2611107
You guys are going to haunt me with the auto thing forever now!!
I was driving around in a manual Lancer in Syd, and just gave back a hire Getz.. Any manual 4cyl is loads of fun on the street. You can rev them hard and your not doing anything dangerous...good fun. An auto means its simply going to be a nice quiet car to A to B in....which means you will be retired whilst im scooping up dog shit from driveways because cars have left me broke ;)
https://www.sau.com.au/forums/topic/140030-the-new-car/#findComment-2611191
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
