  • Replies 353
Posted Images
i thought u get a massive fine for having an exhaust without a cat?
but i would like a bloody curdling exhaust :ninja:
if you dont have a cat dont you get a yukky petrol smell when you are driving, i think i read sumthin along those on these forums sumwere lol
you only get a fine in all the other states. here you get sent over the pits and they will tell you to fit a cat. if i get stickered i will just refit it. i build my cat replacement pipes to be a straight replacement for the cat so changing them over is a 5 minute job. i dont get any strange smells either although you may get a little discolouration of your rear bar around the muffler.
i have a 3 " straight through cannon style muffler , no cat and 3 " straight through front pipe and catback . havnt found another which sounds quite like mine . can replicate the cat back if you like the sound for $800 fitted inc muffler
kermit
kermit
well ive got the twin 3 inch front pipes that merge into a 4 inch collector that goes into my MetalCat, then 3 inch all the way to a quiet kakimoto, so all id need replacing is the muffler. What mufflers (cannons) do you use??
to be honest i cannot remember which brand it was (nothing flash to be honest ) but i do remember where i got it so i can source more plus they only cost a couple of hundred bucks.
as soon as my car is running well ( my guru is hopefully fixed it already) again i will be making myself known at cruises . so i guess you can hear it in the flesh.
kermit
kermit
sounds good, let me know when youre up and running
what diametre pipe is it? does it require silicon hose? a rough quote would be about $120 fitted and polished but it does depend on the diametre.
kermit
what sort of cost would it be for an intake pipe for a hyundai excel ( :D )
bout 700mm long with one 45 degree bend
Krammmitttttt once my engine is fitted and gets retuned, I'll need you to knock me up a new straight pipe with muffler.
I'll see you before then anyway more than likely!
Why is GTR for sale :( Surely Vin won't be happy, as neither will u :) Going to miss that EVIL machine
hey mate. sorry but i wont copy stock parts this way. the only way i would do it is to have the car and build to suit . one tiny difference means that it wont fit and then my reputation is gone.
kermit
i need dumps and front for a r33 gtr . no fitting . could supply the stock ones if you need them to make up new ones while the turbos are off . 3in stainless
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
