Fish N Chips Poll
71 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 52
You might think this is weired, but try it and you will see what I mean.
I put vinegar , soy and salton my Fish and chips.......tastes great ...
Soy only on my dimmies....South melbourne market ones have the Mushroom soy so no salt needed.
I want some now...
best fish n chip shop ever.. esp since I dont eat fish.. is in thornbury at cnr plenty & high st.. 'seafood junction'.. they have huge chunks of juicy chicken breast they call nuggets :happy:
Anyhoo I voted DGAF but I'm with Geoff on the gravy thing... don't think F&C shops have that down here tho.. usually. Have to go to the SAU meeting for that ;)
tartare on fish and chips
vinegar on potato cakes (or potato scallops as NSW freaks call them)
kecap manis on steamed dimmies
nothing on fried dimmies
Dudes dudes you've got it all wrong! Vinegar on the chips or gravy (with salt) Soy on the fried dimmies! :happy:
None of the above. Where is the choice of Salt and Vinegar or Lemon or Gravy on the chips.
Dead horse is for pies. Soy is only for dimmies but hot chilli is better.
Friggin' philistines.
I swear it's like living in a whole different country that is nowhere near Australia down here sometimes.......
Thank you! ;)
tartare on the fish, Heinz tomato ketchup on the chips/potato cakes, (gravy and chicken salt are also acceptable) soy on the dimmies.
freakin bogans putting tom sauce on their fish :happy:
Edited by R32gts-t
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
