Hey all never thought about this and if its possible, but im thinking of flying over east next week to buy a car, and was actually thinking while im at it, drive the car back to perth myself and make it a road trip instead of getting it shipped here, would cost me the same with fuel i know but would be more itneresting. anyway.....
My question is...is there any way to disable a turbo on an r34? maybe pull some boost hose out or sumthing? seems abit useless for the turbo to be constantly spooling on a 3000km journey.
Any ideas?
cheers
Edited by supraaah
https://www.sau.com.au/forums/topic/144505-is-it-possible-to-disable-a-turbo/
cruising it will probably not even be making positive pressure, it will be fine.
the way to 'disable' it would be to wire open the wastegate.
well lets just say im in 5th gear and not quite doing the speed limit, it would be spooling up abit wouldnt it? i mean the nallabor plain is a long road my foot might accidently get stuck on the accelerator.
any idea where the wastegate is? and if that would be a viable option?
BTW- i have an external wastegate on my supra (50mm chinese HKS copy) which has seized open, and my turbo still spools up, so wouldnt that be the same principal ur on about? in which case turbo still spools.
Edited by supraaah
if your wastegate is seized open how are you getting boost ? dont they vent excess boost ? meaning if its open before you reach set boost level it wont go anywhere
you would use more fuel by "Disabling" the turbo for your trip than you would using the thing.. and even if your cruising along at 160kph you shouldnt be seeing much boost to maintain a cetain speed if any at all
remember.. if you disable your turbo it will be a gutless bucket of junk to drive!!!
Edited by rb26s13
You're nuts mate. If you don't want a functioning turbo don't buy a turbo car. If you do buy one just drive it. That's what they were built for.
I second this. Drive the thing, you will soon find it doesn't just boost when on steady state cruise.
Best way to disable a turbo? Tip a handful of shotgun pellets down the air intake. Guaranteed to work :laugh:
I agree with the majority of opinion here - on cruise, the turbos are simply "spinning in the breeze" - you should find that the engine is still under vacuum.
If you disable the turbos, and you find yourself in a "sutuation" (eg misjudged how much time/distance you have to overtake a B-double), then you won't have the turbos to assist you in your time of need.
Just leave the damn things alone.
i would have to agree, on the simple fact that you are driving across a desert in a car that you aren't familiar with. you don't know if the thermostat or clutch fan is working properly. so you run the risk of cooking it on the way. at 100kmh there would be plenty of air going through the radiator, but it could still get rather hot. and if something breaks you could be stuck in the middle of nowhere.
to those of u with helpfull and productive comments ...thanks, to the rest of u no one asked u to comment if u dont agree, notice i said "just an idea" i own a supra (hence my avatar) with different turbo setup and different gear/diff ratios, doing 160 even in sixed my turbo is spooling up quite abit, now as a newbie to the r34 i have never driven one, im buying it on my brothers behalf. Once again, thanks to those with productive comments :)
dont be so one sighted, there are different caars out there, if an r34 wont be spooling up at that speed, doesnt mean others wont...thats why i asked
no car would spool up at light cruise at 100km/h
even at 130kmh. the turbo has no relationship to road speed
it only cares about exhaust gas, which is derived from engine load
load the engine up, and it will wind up
the turbo will only spool if you open the throttle
engine load makes exhaust gas, exhaust gas makes the turbine spin
so once more
no car will make boost unless you pull the throttle cable enough
it wont under any circumstances staring winding in 12psi if you are just light crusing along the highway
supraaah - serious answer is that you will not be boosting at all infact you will have negative boost ie. vacuum. at cruise - which is most of the time so you will be just fine in the fuel economy department.
Also there is very little increase in fuel consumption and a lot more efficiency to be had from using the turbo when you are accelerating.
If you are wanting fuel economy what counts is how long you can maintain a cruising speed vs accelerating time. So if you drive in a way that you brake less and therefore don't have to accelerate back up to speed you will get more fuel economy. Accelerating hard onto the freeway will not see you use more fuel! What you will get is better power to weight ratio output from your lighter engine which has a turbo instead of a larger and heavier engine.
Once you drive it, check out the boost guage, this will show the boost negative or positive. Its definately extremely negative when you are cruising.
Do try to drive when accelerating with the rpm in the powerband where your engine is most efficient ie.over 2200rpm.
Don't forget the energy is used to get you up to speed and lost in braking. How hard you accelerate so long as you aren't going to brake for a while especially makes almost no difference to the fuel economy.
So feel free to use that boost to get you up to speed but try to maintain the speed without having to brake. If that means driving slower to make it through all the lights in the city without braking or coming up to a lower speed so when you do brake you don't lose as much energy from your last acceleration thats the way to go for fuel economy.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
