  • Replies 148
Sad to hear, hope everything turn out to be alright.
Wasn't there a case happened here in Melb, some guys lost their car and 6months later found what looks like their car's parts being sold on the trading post?
They came around with Under cover cops, pretended to buy the parts and turned out to be they were actually their car's parts and so these Middle East guys got caught.
This is such a well ORGANISED crime, if they ever happened to get away from what they just did, chance is we wont' even see the parts in Aust anymore, definately be over sea. If you think its hard to ship 6, 7 cars out of the country, think twice because remember how a Koren Ship sliped through, enter our water, got to Geelong without notice while trying to off load Heroin?
Anyway, just my thought.
Complete Bullshit!!!!!!
Disgusts me how someone can take a car like that have... Although the fact of the system being down indicates either someone inside or some serious organised professional to pull of a job like that..
as someone said all the work and time spent on making the cars what they were can never be replaced...
Hope they find the cars and not too much damage is done...
:S. i think alarms will be headed to GPS monitoring soon.
They have been for many years mate.
It costs less than 1k per year. Few mates of mine use it... and have as long as i've known them now, easily 4 years.
Theres more likely a snitch, one of the employees, or maybe a customer who really likes to hang out there alot. No pointing fingers though, just a hunch. Really feel sorry for the people whos cars where stolen, what i dont get though wasnt there any cameras in the workshop? or atleast alarm system?
camera's and alarm...the recorder hard drive for the camera's was stolen as well...and the alarm had no cellular dialler.
We have them in our cars, the only on-going cost $9 per month for the sim-card, the other one no cost unless calls are made .
It uses GPS to lacate the car and GSM to call you, if it moves, someone opens the door, starts it , cuts the main battery or even low battery ( bellow a pre set volt value).
Much better system that QT as it has unlimited cover as long as it is above ground ..
Edited by wrxhoon
ah, cheaper these days lol.
Must admit i aint looked into costs for a while, cheaper than i thought
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
