1 Golf club (GTA Vice City & San Andreas) he has a better swing than me
2 M1 Garand (Any WW2 FPS)
3 Farsight XR-20 (Perfect Dark) Shoots through walls
4 Springfield 1903 Sniper Rifle (Any WW2 FPS) Get to be pvt Jackson from Saving Private Ryan
5 Shock Paddles (Battlefield 2)
no particular order
.357magnum GTA:VC
ak47 GTA:SA
artic warfare magnum CS
desert eagle CS
m1 garand BF1942 (matter o fact - a lot of rifles in BF1942 in many of the mods, they all seem to be aright)
Rise of triads was good, but i would have to say
Steyr- CS
Twin Enforcers- UT
Ion Cannon- C&C
Seeking Rockets- Halo 2
Petrol can and matches- Postal
And many others deserve to be here, so many cool weapons have been invented over the years, now for real life to catch up, bring on the mechwarriors
Shaft (lightning gun) from quakeworld
RL (rocket launcher) from quakeworld
thats all.
lol
qw.. haha those were the days... hmm i still have it here 2 but dont play TF anymore :)
1. proximity mines (goldeneye)
2. proximity mines (goldeneye)
3. proximity mines (goldeneye)
4. proximity mines (goldeneye)
5. proximity mines (goldeneye)
twas z best :pirate:
5. Pipebombs and Laser mines - Duke Nukem 3D (just for the fact you could litter a room and destroy everything on entry LOL)
4. Redeemer - UT
3. Freeze Ray and Shrinker - Duke Nukem 3D
2. Railgun - Quake 2
1. Cerebal Bore - Turok 2
and if you haven't seen it have a look at this...the top 10 weapons in games..... http://www.youtube.com/watch?v=Q17oeFtLvvQ
Edited by hobzta
Yeah the rail gun in Quake 2 was quite a difficult beast to master.
It's shot travelled a lot slower than the one in the original quake.
Quake 3's railgun was awesome though.
There was no railgun in the original quake
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
