Hi Guys,
I was bouncing around the idea with some of the exec committee of reserving a bunch of track day spots for an SAU event at a few track days during next year. We could have a group or two set aside for SAU members and we could run a function within a track day.
Let me know what you think. I have 8 days booked for next year.
Paul
https://www.sau.com.au/forums/topic/146935-sau-group-at-track-day/
  • Replies 109
very keen.
that case,my car will be covered by shannons as well in case i crash on the track.
frank i think you'll find u wont be covered whilst at the track, unless it has changed recently?
sounds like another great plan paul ;)
Cool guys.
Lets get some bookings sorted. I think if I put aside two groups for a half day (20 cars) that would probably be about right, if we put the chosen dates out early we will be able to hone in those numbers.
A lot of guys come to every event anyway, so maybe two or three dedicated dates where you guys will do the SAU thing would be good.
Let me know what you are thinking and we will work out the best plan.
I have the AWD Shoot-Out on March 28, and it would be good to see SAU support of the GTR team out there for that !!
Also there will be a RWD shoot-out coming as well where I want to see our GTS drivers represent !!! (not sure when or how yet on this one)
The coming dates are:
Feb 2
March 28 - (AWD Shoot-out afternoon)
May 17
June 26
Aug 23
Oct 5
Nov 27
Dec 13 - half day christmas party planned.
Paul
PS: Hey Col, I'm curious on this present.....
PPS: Dave, although the hot track is harsh, it does deliver good lap times !!
May 17 or June 26 looks like a go for the air temp reasons... Turbo friendlly...
The present well its just a thank you for letting me be a part of your event and making me feel usefull...
Well I got you some black printer cartridges (BCI3Bk x 2) for your "Canon" I550 printer, I took notice to the model of printer you use to print all the lap times and info on at the last trackday so I get you some freebies from work to use... (Lucky its a Canon)
Its just a small thank you and I know you will use them...
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
