  • Replies 392
Hi,
Recently purchased a 200SX, with some mods done, and wanted to get a dyno run in before i did any more mods to the car. I know it has a SR20DET and not a RB series engine so its cool if I'm not welcome to attend.
Also - just to be extra difficult - I start work at 230pm on the Gold Coast that day... So if its possible to be slotted in before 1pm'ish that would be awesome.
So can I come along?
Side question - cos im a noob and never had a dyno run - do you guys worry about ambient air temps for dyno runs? Like if its a really hot day, you'll only run 14psi instead of 17psi etc.
Edited by Grrr
also ... how do I upgrade the motor where my avatar should be from an RB20E to an SR20DET? :)
hah, i only found this last night after 2 years..haha
go to: my control, then, Edit Profile Information then enter the sr20det in custom member title :)
Hi,
Yes by all means, this is an open dyno day. All makes and models... More than 90% of the cars on the rollers will be skylines, but your more than welcome to come along. Just read the first post and when your happy give us the nod and your in...
As for running early in the day thats not an issue, we will fit you in before 11am so you have plenty of time to take off when needed...
As for the boost setting, you said your car is slightlly modified. At 17psi I hope you have aftermarket fuel management, injectors, z32 afm and an aftermarket turbo... Cause if your running 17psi on any stock components your gonna blow your engine up within 4000-5000km's...
I always say run the boost your management is setup to handle... I wont be turning mine down thats for sure... :)
Please in future post these sorta questions in the help area of the forum, not in the middle of a dyno day thread... Thanks
go to: my control, then, Edit Profile Information then enter the sr20det in custom member title :(
Thanks Series II...
Awsome! Thanks Col and SAU. :yes:
<--- Thanks SeriesII
Most ill run is 15psi... I was kinda refering to you big boys with your big toys :) Actually 1/2 the reason for wanting the dyno run is before i do something about the engine management.
Please in future post these sorta questions in the help area ...
:happy: sorry.
So yes put me down and ill internet transfer the money on the 1st or 2nd of the month after I get paid.
Edited by Grrr
No worries your in...
Ill note an early run for your car so you can rest assured that your in and out in no time...
Josh has lead a sheltered life...
Geebung/Virginia are no worse for crime that Noosa or the gold coast... The people who live in the area are generally working in the industries based in virginia.
So they are hard working families and yes I would feel comfortable walking through there at night... Its probablly safer than hastings street or cav ave...
No mase required... Just Josh is scared of everything out side Noosa...
You know i'm just playing :happy: I'll give you a hug at the dyno day to make up for my naughty talk of Geebung :)
P.s, speaking of crime, someone broke into my little red swift.... Took the head unit and amp :yes: Damn Noosa and our high crime rate!
Edited by Nismo_Boy
Awsome! Thanks Col and SAU. :(
haha, thats all good.. i was happy when i found were that change was to.. hated the rb25de, with no T, is there a point..hehehe .. thanx for the shout out in your avatar.. crazy..
hey grrr, are you from the gold coast?, your going right/?, i just need to follow someone, as im to lazy..heheh
Edited by seriesII
Following me is not a problem. I just need to get myself a UHF radio by then...
sweeet thanx..ill pm when we get closer to the date, so i can make sure to get the day off work :(..
uhf radio?, still have the jap am/fm tuner in your car?, i have one if you want it, its just sitting there behind my deck..
dont think you quite understood... he meant a hand held UHF - for talking to other people - sorta like a CB truckies use
ps ill transfer money when a get paid at the end of the month
OK
Time to ramp up the payments people...
2 weeks till the payments close... I have re-done the list on the first page of the thread, remember your spot is not secured until payment is verified by SMR33... First 40 payments are locked in as a 100% run...
ahhh, haha, thanx for clearing that up.. hehe, walkie talkie or 2-ways.. lol... i think i can steal a good pair of my parants, as my dads friend is a cop (shhhhh) and i take thing all the time to use..hehehe. ill try and get a whole bunch of uhf 2 ways.. only for the gold coat ppl.. heheh
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
