  • Replies 157
Posted Images
BP ultimate is no problem When I made the jump into the 400RWHP I went with injectors. I put in 680cc HKS but it would probabley be a cheaper option to go with a similar size nismo as they will fit the original rail. It sounds like your combo is similar to mine. Originbal build RB26 , -5's, Power FC, dumps front pipe 3inch exhaust, cam gears, apexi filters, aftermarket FMIC. If it original build you may wish to consider how hard versus how long you want this thing to last. I made 450rwhp but backed it of to 430rwhp for the sake of longevity. Each application of the technology will produce different results on different platforms, add to that different tuners and its really a per application judgement on how far to go
sard 700s are the go. they are cheap, and bolt straight in. they also work well with the PFC, ie, no problems with lag timing etc.
Dont you have to sort out some "o" rings with those Richard???
I actually have a set of SARD 850cc's that I had lying around the house...
Do you think these are overkill for the state that the GTR is in at the moment?
I had big plans for my previous GTST which is why I have them and not sure what to do with them now..
Sard 700's are direct fit , you can use your old O rings ( a little tight but they will fit ), of course I would always use new ones , unless I changed them recently.
Sard 850's ( the twin spray ) are not direct fit , you will need different plugs .
Why would you want 850's or even 700's with stock turbos ? the 440's should be just fine with stock turbos .
I had stockk 440's on a 33 GTR that had Group A N1 turbos ( 1.2 bar boost) Ah and don't tell me she didn't haveany power , she was good for 11.7 1/4 mile and a trap speed of 121 mph!
all this talk about power with these turbos...
which of the turbos (t517z, GT-SS, 2860-7, 2860-5) would be the most responsive??
what exactily are each individual power ratings
GT-SS - 300ps or 320ps ??
2860-7 - 290ps or 310ps ??
im not chasing big power figures want as little lag as possible but still decent power upgrade from standard
prob dont want more than 300awkw
sorry for all the questions
RellikZephyr
i was just reading the Garrett website site
and it says that the 2860R-7 is quote... "OEM on Nissan RB26DETT used in Skyline R34 GT RN-1"
now i heard/knew nissan used garrett for their factory turbos
and is that saying that the 34 GTR N1 turbo and the 2860R-7 is one and the same?
EDIT: Anyone with 34 N1 Turbos, where is 1 Bar boost available on stock engine? 3500? 4000?
Thanks
RellikZephyr
Edited by RellikZephyr
If they arent "exactly" the same, then they are close enough :ninja:
Someone posts the specs in another thread of them all... i cant remember if they were 100% the, but yeah, if they werent, it wouldnt make much diff
GT-SS/-7s/R34N1's all make around the same power, all with similar response
and how is that response??
judging around 1 Bar of boost
where would that be available in the rev range??
just trying to get an idea
Thanks
RellikZephyr
That will depend on the engine that you have ( spec, condition , etc...) and the load. On my low K series II 34 in 4th gear i see max boost 91.1 bar) at 3800 rpm not much later than stockers.
I have GTSS turbos though.
  • 3 weeks later...
I removed all the broken teeth from my box and have been driving -around with no 3rd. Looks like I have an OS box lined up.
I have recieved my FC-Datalogic so been doing some tunning. No idea on power levels, however boost response is insane and dataloging indicates faster accel between 1st and second with 1.4bar.
anymore results with the turbos mate..
  • 1 month later...
You using an Excedy Solid Centred Twin? That seems to be a regular common link with busted R32/R33 gearboxes....
I've f*ked two gtr gearboxes using an exedy twin plate clutch
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
