Wasnt there a season (1995?) when Benetton had customer Renault motors and Williams ran the factory Renault engines? What about Jordan in 1998/99 wiith Hill and Frentzen. They werent factory Honda engines, werent they back door Mugen? Honda only officially returned to F1 with BAR (this is from memory so ????)
Still, i think it has more to do with lack of finances / expertise meaning you outsource you engine development. the same lackl of funds means you dont have the right engineering staff, teh right drivers etc etc.
  • Replies 2.1k
Posted Images
i think djr81 owes us a whole lotta love. :rofl:
remember though were only talking about "customer" engines, where the team has had to pay for the engines and not be supplied arbitrarily by an engine manufacturer.
benetton and ford on 94 is an interesting case though..was it a works engine or paid for by benetton? i have to check.
Edited by m3gtr
speaking of the 94 benetton, i just stumbled across this amazing website with a very collectable item for sale.. :rofl:
anyone for a WDC winning machine??
http://www.race-cars.com/carsales/other/11...157661450ss.htm
Edited by m3gtr
were Jordan still running mugens when they came close the WDC? Or were they proper Honda's by then?
If memory serves Honda were not in F1 under their own name at that point, meaning the Mugen engine was not technically a customer engine. In previous years it had been basically a badged version of obsolete variants of the bespoke motors.
I was thinking more along the lines of say the Renault relationship with RedBull, or perhaps Ferrari's with Sauber.
Mind you HHF came mightilly close to a drivers crown in '99. If only they hadn't coughed it up at Monza. They were still Mugens in '99 I think.
i think djr81 owes us a whole lotta love. :(
Benetton had a works deal in '94 with Ford. The motors were no longer badged as Cosworth by that stage.
In '95 they had Renault motors. I reckon you could reasonably quantify it as a factory eninge deal because the motors were every bit as good a the ones in the Williams.
The best I can come up with is McLaren in 1993. Senna won 5 GP's with a customer Ford engine that was always an evolution behind the works Benettons versions. Ron Dennis had to sign a cheque to get them too.
Yeh when Schuey picked up the WDC on 94 for the first time it was courtesy of Ford power. But the customer Renault deal in 95 made Benettons life easier when racing Hill and Couthard.
In 93 the Ford engine was sure a lot better then thge Peugot they ended up with...ooooh thedark days of McLaren, remember that monstrosity that Mansell ran at the Aus GP? :(
And now another reason for me to hate Hamilton...he is boning the 18yr old daughter of the TAG squillionaire who as you would expect is rather easy on the eye.
I think a good union hit into the water will do his season in. Hell if tennis did Montoya in then these little fellas woudlnt be hard to break... :)
and here is our problem troy:
when you're a teenager watching these guys in their mid 20s race F1, bang hot chicks and cash their multi million dollar cheques we look up to them thinking "that could be me one day". Now they are younger than us we are looking at them thinking "f**k, that should have been me". Though I guess there is still hope for us, after all webber and DC are in the 30s and MS raced well into his. Jackie stuart I don't think even started F1 till he was 30 something.
that chick really doesn't look like anything special...not in that pic anyway. she looks about 30....
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
