Cool!
http://www.automobilemag.com/auto_shows/20...er_evolution_x/
X is Roman for ten. But we'd like to think it denotes and X rating--for the meanest, rawest Evo ever made. This future rally rocket was first previewed by the Concept X from last year's Tokyo auto show, and now a closer version is being shown here at Detroit. When the car goes on sale around this time next year, power will continue to come from a 2.0-liter turbo four, but output will push past the current Subaru WRX STI's 300-hp rating and a new, aluminum block will be used. Because it would be a shame not to use the new Outlander SUV's lovely magnesium-alloy paddle shifters, an automated manual transmission will be offered alongside a traditional 5-speed manual box. Naturally, the Evo will be driven by all four wheels, via a new S-AWC (Super All-Wheel Control) system that Mitsubishi promises will rival Honda's SH-AWD in sophistication. The new system will feature active steering, active yaw control, and myriad electronic sensors. We hope S-AWC doesn't compromise the great steering possessed by Evos VIII and IX--after all, Mitsubishi promises this will be the "largest leap in overall capability between two generations of the Evolution."
https://www.sau.com.au/forums/topic/150673-evo-x-prototype/
Very nice indeed. The recaros and rims were missing from the other pics of it floating around the net. Very interested to see market response to it. Maybe I should put a deposit on one if Mitsubishi has confirmed local release :(
https://www.sau.com.au/forums/topic/150673-evo-x-prototype/#findComment-2805068
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
