I heard that a EVO owner who will remain nameless the last time he seen your car take off he turned to the person next to him and goes "now we are in trouble"
So go Giant stick it to 2 the EVO`s
isnt it good that gtr's can have that effect!! :laugh: cheers mate
and yeah evo,s are great, just not as great as gtr's!!
evomick top video !! well done and look forward to meeting you.
cheers russ
p.s did a track day today! and the brakes were fantastic!
  • Replies 150
Posted Images
cheers russ
What brakes you running??
Weren't hapy with the AP's???
we were having issues with brake vacum loss, & needed to get rid of the vacum booster to get a consistent pedal feel( i actually crashed with no brakes late last year)
a pedal box lets you get rid of the booster and allows for greater adjustment in all areas and gives great feed back through the pedals on braking along with brake bias adjusments.
attached is a pic of the unit fitted.
cheers russ
Hopefully you won't have a repeat of that hey Russ. Was the vacum loss basically causing the ABS to play up (which is an issue I seem to get on and off) or was it more of a pedal pressure loss problem?
Anyways regadless it will be good to see you guys out in it again. Although when are you guys going to unvail the R33 mate?
isnt it good that gtr's can have that effect!! :yes: cheers mate
cheers russ
I love my EVO`s to it just that one of my mates has got one so i need bragging right :rant:
ugh i didnt know it was that black gtr that crashed, i remember watching it at the nsw round last year, clutch in, select's first gear, bang car jaults forwards. ugh such a tough car. i think you ran something like a 10.6 odd with hell old semi's... my mate at work will be there in theyre new evo 9... sock it to him!
Belsil80 the brake pedal when properly setup is firm but has a really great feel to it(so far!!) can lock all four easily if required.
evo cam's car is a weapon thats for sure & it's going to be good to race with him and have some fun too aas that evo is only going to get better.
roy the r33 is slowly getting there hopefully by march it should be up and running everything is pretty much done now except the block which is happening now. we are hoping for a nine second pass on the 1/4 for it's first outing but we will see soon enough. how's your machine going & will ya be at the nsw dutton??
cheers russ
Edited by giant
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
