i thought i saw in his nick/sig 35 at some point.... anyway wouldnt the 30 be a bit on the small side, whats it like to drive cubes? must spool quick
It feels perfect and doesn't ease up until the 7000rpm rev cut.
Its all in a shade over 3000rpm and making a good 7-8psi by ~2400rpm. Extremely responsive. Perfect roll-on acceleration turbo.
I found the GT35 .82 to lack the roll on response in second gear; it felt as if you would always hang level then click third and hammer away; with the gt30 its instant go.
The GT35 doesn't really make its peak boost much later in the rpm but the transient response in comparison is very very noticeable especially in the lower gears.
To drive it feels less laggy and with more torque everywhere than an rb25det with its std turbo.
And the interesting part is for under 300rwkw with the stock exhaust manifold they both make the same sort of power for the same boost. Which is why I don't recommend the GT35 unless your going a nice exhaust manifold and cams to really make use of the potential.
You really need to drive the two setups both on std exhaust manifolds with std bits everywhere to see where I'm coming from.
Was speaking to Tony Rigoli tonight at WSID and he said they make their own sump adaptors but use 10mm sump bolt holes (same as RB26) not the factory size. He said with the extra weight of the sump/diff the standard RB30 holes aren't adequate.
Thoughts?
10mm bolts on what side of the adapter
plate to block or sump to plate?
theres 17 M6 & 6 M8 bolts holding the plate to the block. then theres 8 M6, 7 M8 & 13 M10 bolts holding the sump to the plate. whice imo is more than adequate
Thoughts?
I used a RIPS plate before Pro Engines started making them, as far as I remember they use the standard holes and have been doing so for years. When I see an RB30 with the bottom torn off I'll believe they need bigger fasteners.
Cheers
I was only passing on info from a highly respected engine builder....
I took the sump of my rb30 this morning, was actually suprised how small the bolts were but then their were plenty of bolts.
Can anyone give me a fairly close estimate on the weight of and RB30DET for freight purposes Complete motor with clutch and GT3540
any recommendations of freight companies more than welcome too!
need to know asap
does anyone know if a RB30DET with low compression RB30ET ACL pistons with a 3 layer cometic head gasket be a interference engine ? or non intererance ?
Would the valves smash the pistons if the timing belt let go?
anyone know?
after getting my RB30E and my RB25DE, and taking the head off the RB30E....What is recommended to be done if im wanting to replace
i.e. measuring/checking etc etc
a)main bearings
b)welsch plugs
c)big end bearings
d)piston rings
anything else anyone recommend to replace bar rods and pistons...
Cheers David
a)main bearings
b)welsch plugs
c)big end bearings
d)piston rings
Cheers David
All the seals ie. sump, rear main, head gasket, oil pump etc...
Make sure u clear the oil feed gallery for the turbo in the block as every na Rb30 I've seen has been blocked with sludge.
Edited by Alf
anyone know?
dont mean to sound rube but what difference does it make? your going to all that effort just buy a decent timing belt and its not an issue
I think the whole thing is, he might want to build a non-interference motor incase the timing belt lets go...
With all the engine failures recorded below I've only seen a couple when the belt let go. Just heard of one this morning but no detail yet. Of the others I know it was either a poor quality bolt in the idler/adjuster and a cam cap galled and the belt jumped a bit (GTR cams into RB20) so I've yet to actually see where the belt has failed instantly and catastrophically. There is usually noise and time to inspect the problem.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
