  • Replies 838
Posted Images
currently playing the ass out of Forza 3, but have been thinking I might go and buy Oblivion for the 360 and play it through without cheating... would take a hell of a long time but would be wicked fun :D
currently playing the ass out of Forza 3, but have been thinking I might go and buy Oblivion for the 360 and play it through without cheating... would take a hell of a long time but would be wicked fun :cool:
i think i racked up nearly 50-60 hours on oblivion, only finished the story plus 3 of the guilds.. i spent hours trying to get rid of my aids after i slept in the wilderness and some vampire bit me..
Currently. UFC 2009, Batman on PS3
and been going old school a fair bit lately also
Jagged Alliance 2, Sim Farm, Transportation Tycoon, Scorched Earth (PC).
And on Emulators/Roms
Seiken Densetsu 3 (Snes), Mario Kart (Snes), Mario Golf (N64)
been playing operation flashpoint 2 and need for speed shift, both are kinda meh, though nfs:s is more enjoyable so far
operation flashpoint gets better as you go along, gets frustrating at times walking 4 ever then if u make a mistake haha
im playin forza 3 at the moment was gona take it back but finally into the good cars and its not bad graphics are crap after playing dirt 2 tho
Finally agreeded to all the hype around Uncharted on PS3 so bought that last week, loved the game, it actually stopped me playing NFS shift just as i got bought the pagani zonda...
Also playing Red Fraction Gureilla, gotta love explossions!
And still playing GT5 prologue... patiently waiting for the full game...
I hear Uncharted 2 kills number one so I'll prob be getting that...
oh and I'm liking the look of boderlands...
  • 3 weeks later...
I finished that with my missus... we are both highly competative. We were at each others throats blaming each other for each one of our deaths...
I just stay out of her way now :(
oh yeah, and I got Borderlands over the weekend... very fun! Just my kinda game! :O
lol, I have the same problem. been playing two player with my GF too and often end up getting each other killed, or accidentally hitting A at the wrong moment and ending up in a bubble only to watch the other die and we both have to start over. good fun though. :(
There's been a few times where I've gone to do something tricky for a star coin or something and told her to sit tight so I can bubble for safety if I need to... She freaks out and bubbles as well so we lose :(
It was good fun to start with, but I think we're taking it too seriously now... we're trying to get all the levels in the hidden world...
loving super mario brothers on the wii. good fun. :turned: almost as good as the original.... lol.
Being playing this as well
I just stay out of her way now :D
oh yeah, and I got Borderlands over the weekend... very fun! Just my kinda game! :)
Well at least you guys are cooperating, when I played with my friends we were all being complete arse-holes to each other, sometimes killing each other on purpose... :)
I just stay out of her way now ;)
Been looking at this one. Do you play it with your missus too?
Also, if the two of you are playing split screen, can you play with another couple of people via internet? (so 4 players, 2 PS3's)
Edited by iamhe77
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
