Need quick advise please .....
I have a car that is currently registered with SA plates for another couple weeks. I want to give it to me pa (who does about 20km's a month lol) so obviously it needs to be registered in vic. Now, do i just go to VicRoads and transfer it to Vic plates then get the transfer papers to transfer to me pa name? ...or is there an easier way? If i get the roadworthy myself will Vicroads want to inspect the car at any point in the process?
Also,
If i let the reg expire can i just go out an get a roadworthy, take that along with the transfer papers to Vicroads and get it transfered straight to his name with new reg no fuss? ...will Vicroads want to inspect the car at any point if u used this process???
Whats the best, no fuss way without having to take the car to Vicroads ...??? :P
VicRoads might, best to ring them on monday
Sometimes they do, sometimes they dont. There is a criteria surrounding it but i cant remember honestly.
If its de-rego, same story. Some people ive known not to need to, but then i had to myself... so its all up in the air.
Best bet, get it here. And do the transfer to vic/pa's name at the same time. All you do i register it in Vic in his name in the first instance.
Bringing it here, transfer to your name, then to your pa's is just too long winded when you can go SA reg --> Vic Reg/Pa name at the same time with a RWC
quick question
if a cop/epa officer spots your car on the road and sees it as being too loud etc, can they send out a letter to you for a FULL epa emissions test or NOISE test only.
My mate got pulled over by a cop last week, popped the hood etc etc. This 32 (engine wise) is nearly dead stock apart from turbo back exhaust and pod. After the cop checked it out we got a defect notice for ride height too low and then a FULL EPA emissions test needed??
Under the hood is completely legal (1 intake mod)
I guess if the police officer wants to be a dick they can send you out for a full epa emissions test if they want, correct??
Edited by willL
quick question
As with more and more matters it is "At the officers discretion".
hey guys, just a quick one. Got pulled over on dandy road last night and had my bonnet opened, now clearly I was in breach of the 1 intake mod thing, but I was not handed any form of infringement or even told I would be.Copper one had the measuring thingy and she passed. Copper 2 (was a right hottie :) ) had the torch and was checking everything out.... Are you normaly advised if they want to send you to the e pa? And I live in gippsland, so afaik I dont have to go @ all? Can anyone confirm this? :)
Thanks in advance!
No they don't have to advise you on the spot. :)
Ive never been advised of any EPA's ive had in the mail.
They can just go back, paperwork, EPA in the mail.
Its that easy for them as there are no rules surrounding it which makes it a fair load of crap :)
Sounds like run of the mill officers, they generally aren't too hard
Thanks for that Ash. Yeah I think I was lucky. They had seen me pass them some 2 hours earlier and were quizzing me on what I was doing travelling up and down dandy road.
I will be surprised if I get anything in the mail, but it certainly makes me think twice about modifying my car further!
hey guys, anyone been down to have their car EPA tested in moorabin? i'm due for a check and was just wondering how strict they are with the test?and if they are nice or not about it. lol
i rang them today and they said the whole car would be looked at, and would take an hour! the EPA in McLeod only took 15-20 minutes.
cheers.
G'day all,
I've got couple of q,
1, Would I need child resistant anchorages to pass rwc? (my 33 didn't come with one - speakers was in place) - couldn't find info @ vicroads site and my local mech have no idea.
2, Who have good RWC place near Frankston area? (Need second opinion and went to couple and they won't touch skylines for some reason)
Thanks in advance.
Cheers
Grant
cheers.
Dude was fairly chilled but by the book. I failed for 4db over but he didn't care about the epv in the exhaust, however made me change it and redo the test.
They wont pass a car, thats not legal. Its that simple.
If they get busted its fines and could lead to a loss of thier approval/saction as a tester and thats not really worth it for them
  • 3 weeks later...
i rang the moorabin mechanic where my car will be tested, and they said it will have to be put on a hoist and all.. so would that mean some of my oil leaks could be a problem aswell? its not really an emission, but could it still be considered an environmental problem?
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
