The Epa Thread/Roadworthy Thread
Do-Luck
just got pinned today... :P
i can get the RWC part sorted (ride height, seat belt retractors and non padded steering wheel, afaik - still waitin on letter) but its the EPA i'm worried about... copper didn't say if it was a full test or just exhaust vol and i was WAAAAAAY too scared to ask him as he was in a FOUL mood when he pulled me over.
i have an aftermarket turbo (not highflow but lowmount) / ecu / injectors / fuel pump / BC / exhaust etc
if its a full test and i just put on the stock zorst from the dump or cat back and change out the ecu for the stocker am i gonna pass or are they going to look @ the turbo and simply say no way?
i'd MUUUUCH rather not have to go changing out turbo's as its only been in a week! :)
If you get the full test you will need to remove ecu/inj/turbo & bc. If the pump is just an in tank you will be fine. You might even be ok with a big one in the boot or similar, I never had my boot opened the 4 times I have been.
They will see the colour of you injectors is not normal and you will fail, they will see your shiny HKS heat shield and turbo (yeah they look that closely) and you will fail, they will check your ecu and you will fail.
To answer your question R34 NRG you roll up into a little booth and they visually inspect the car (engine bay, exhaust setup, etc) they will take notes on your setup incase you re-offend. They then stick a probe up your exhaust and do some emission testing (not 100% sure what they do here) I never had a problem with this section.
Then you move you car out to an open space where they test noise. Basically placing a microphone about 1.5m away from the exhasut tip and reving your car to 3/4 (from memory, might be more or less) of the rev range. You must be under 90db.
They then slap a green defect like sticker on if you fail and tell you you have 28 days to fix it otherwise your rego will be suspended, you cant sell the car in this time either (but it can be driven any time).
If you pass you go on your way and pray you never return
I would advise you are very polite and dont try to lie to them, they really know their sh*t.
Im on my green P's right.. got a r32 gts-t with fmic/pod/bc/turbo back exhaust..
now i know they can get me on the high powered laws if they knew i had the turbo back exhaust and bc.. but can they get me for having the fmic and pod? because stock the car is under the power to weight ratio but if i got rid of the BC and just had a fmic and pod i know they can defect me for having them both.. but can they say my car is high powered because ive modified it and those mods could increase the power?
So what can I do to prove its not.. dyno it and have the sheet's ready if the cop's pull me over to say here are the specific spec's for my car its under the power-to-weight ratio? but then they can say u couldve done that before the dyno etc..
I know the FMIC/POD is illegal for EPA but whethere i get EPA'd or Defected its no big fuss to get rid of the pod.. I was thinking if i get a heatshield made or a sheet or metal covering the pod, i know it wont help me on the EPA side of things but legal wise would it considering the cops wouldnt be able to see it? Or maybe even see if i can get someone to do a custom job with my stock airbox to fit over the pod so you cant see it?
It wouldnt be such an issue if i could fit the airbox in there but apparently where i took it they said theres no room for the airbox, only the POD.. so im not really sure what to do i want to make it look as stock as possible under the bonnet and as legal as it can be til i get off my P's..
From my knowledge, the majority of the time they will go off factory power to weight figures to determin if its oevr what it should be.
If situations where its modded they probably wont accept a dyno sheet from you proving the power, rather they will just tell you to return it to stock or rather epa/defect you for everything under the sun they can find :blink:
wtf a cop pulled me over and could find nothing defect me for and end up major defecting my s2 r33 which is stock height for being to low by .5mm. is there anything i can do to appeal it or should i just get a rwc and clear it
If situations where its modded they probably wont accept a dyno sheet from you proving the power, rather they will just tell you to return it to stock or rather epa/defect you for everything under the sun they can find :(
Under the bonnet my car isnt heavily modded.. Just fmic/pod, blocked off BOV which i need to unblock, stock plumb back is on there, and im gonna get my SSQV welded near the REO. Also got the R33 turbo but im sure they couldnt figure out that i've changed the turbo. oh and BC but im gonna get a new one installed hidden. But coz of the blue paint job and black bonnet i got now it looks really flashy.. Before i got the car painted i had never been pulled over with my car.. 1 week after the paint job and i get pulled over lol
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
    • I had a fuel smell coming from the drivers rear and pulled the tank out to inspect where it was coming from, turns out the breather hose from the tank to the filler neck was perished. I’m going to Japan next week and I’ll grab it while I’m there  pulled the oil tank apart and started cleaning this crap out of it, some brake cleaner and rags got it looking new again
    • Hmm. Was quite a few years ago now. I think I bought from a crowd in the US called CDT Audio. The speaker is the HD-6. The HD-6CF would have been the better option (based on T-S parameters), but they were discontinued in 4 ohm at that point in time. The HD-6 is a better driver in almost every other way (than the CF) - just not as good in IB. They still do the HD-6. They might even have a more suitable (for IB) option here.https://www.cdtaudio.com/cdtnew22/products/components/woofers/midwoofers/midwoofers.htm But, here's the rub. I was working in the US a lot back then, so I got them delivered to my US office and then just brought them back to OZ myself. I don't know if they will ship to OZ, and it probably wouldn't be great cost-wise anyway. As to results. They're driven direct off the rear channels of my headunit, because the headunit can be setup to run the rears as subs. So, not a lot of power being fed there. Nevertheless, there's no shortage of volume - the sub levels don't need or want to be boosted at all. The bass is definitely not what you would call "tight". It is definitely a bit delayed compared to a proper sub. But, with the great front soundstage and really good 6.5" woofers in the front doors, I'm getting most of the bass detail from the front and the rear is really only to extend the bottom end a bit. Works for what I'm doing. I mean - until recently you couldn't really hold a conversation in my car due to the fuel pump, and for many years I had tyres so noisy (Kumho KU36 at <50 tread depth) that I had to drive with earplugs anyway!
    • curious to know what drivers you chose and the results? quik mafs, says two 6.5s should roughly equate somewhere between a single 8" or 10" driver. i agree that IB is definitely the way to go in most cars imo.
    • S13 and R32 rear suspension geometry is horrible once you lower it (which everyone does). The camber & toe out ramp is very aggressive, hence it's common for the S13 boys/girls to use a S14 or S15 subframe as the geometry is light years ahead. I'm sure the same can be done on R32s, but I don't know anyone that has done that.
