Who cares about the pod/intake thing - even though the Officer is wrong it makes no difference to the fact you have to get a RWC.
The exhaust is low, get it fixed and go take the defect to a RWC place.
It's really that simple. A RWC place wont just make you "change windscreen" if there is nothing wrong with it. :glare:
were you clearing a defect or just getting a RWC for registration?
I'm clearing a major defect, so it requires a RWC to show to vicroads.
I know the pod wasn't the real issue, it just showed that a cop can be handing out defects without really knowing anything about cars. I once tried to get a RWC from rapidtune when selling the car. They gave me a massive list of things that needed to be fixed. I showed that list and the car to our family mechanic (he wasn't able to write a RWC) and he pointed out to me the things they had mentioned. Seriously only about 3 out of the 10 things actually needed to be changed. I took it to another place to get the RWC and they did it for a fraction of the price that rapidtune wanted for it.
Unfortunately this time I only have 7 days. More like 5 days now.
I got pulled over today, as you would...
as my car probably does 112dbs or there abouts, he only took down my details and my phone. I have a valve controller that shuts up the exhaust. He said he wanted to go back and do some checks later (he was on a bike).
Should I expect an EPA in the mail?
got pulled over my first time! thought i was doing something wrong when i drove a little onto the wrong side of the road to avoid a car but the officer told me to pop the bonnet and he started measuring the car height and checked under the bonnet, then he said "all stock okay you can go"
You're joking yea
I didnt say "is this defectable" I know it is a defectable Item. But there are many mods that will still pass a RWC as they are not deemed unsafe.
For example, You can get defected by police for not having the H pattern for your gear nob, yet most mechanics will still pass this with a RWC.
So no, I'm not joking. The RWC is to transfer the vehicle only.
Hey guys how are ya, I havn't brought a car for a long time but just wanted to know. I brought a another r33 and it has a cooler and a 3inch trust greddy cannon exhaust with 17inch rims, Now everything else is stock, now i need a RWC under my name to get the papers under my name... would a return-flow cooler still pass at the RWC's and 17inch rims? Besides that everything is stock in the car..
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
