Hey guys,
I'm just wondering who amongst all of you has had their car tuned by Advan Performace in Silverwater.
Reason I'm asking is after they tuned my car I have been experiencing high levels of engine knock, high as in the hundreds according to the Power FC hand controller, and my ignition timing is at 42 degrees which I have been told is extremely high. I have had the engine compression tested, result was 145 across all cylinders, car doesn't blow any smoke or make any strange noises. The drive home Advan the knock level did not exceed 22, then the following day I think it went up to 120 something, highest reading from the hand controller was 200 and something, I'm hoping it's a faulty knock sensor or something. Hasn't seemed to damage the engine at all.
So I'm just trying to find out if anyone else has had a problem with their tuning. I'm thinking of taking it to CRD to be retuned.
Any suggestions or input is appreciated
Thanks
With a power curve like that.
I would be taking it back and asking for a retune, or alternatively something might be wrong with the car, part not 100% or something.
The curve is all over the place. Not what a good tune should look like
I knew I should've taken it to SAS in the first place. One of the guys from SAS told me that Advan don't even have a proper tuner working for them, said they specialise in "bling" only.
Any idea what part might not be 100% to 'cause that sloppy power curve?
that is f**king horrible!
I street tuned my own car and the curve is 100% better then that crap - i hired a dyno the week after to get a couple of power readings and this was one of the runs.. totally different.
How much did the tune cost you ? I cant believe they let a car out like that.
the tune looks fine
the top higher power run is the "after" dyno plot
the lower one is the "before" dyno plot
if its knocking a bit more than 60 then you just need to spend a few minutes getting accustomed with knocking and how to correct it. the pfc faq (in my sig) will tell you in great detail how to work with knocking and debug it correctly.
read that and it will help you sort out the knocking
er, i wouldnt be doing any fixing yourself at all (regardless of how easy it is after reading the faq)
id be taking it back and telling them its knocking and make them fix it
Look at the power surge between 130 - 145 - that looks like something that would happen with rich and retard not with a full power Fc tune.
I would like to see the ignition map and fuel maps of this tune.. there must be a reason why its doing that.. if its not the tuners fault then there must be something wrong with something there.
the tune looks fine
before getting carried away with taking it somewhere else, or accc etc. just go back to advan and tell them your concerns... at least give them a chance to help you out. I'm sure if they did make a mistake, or possibly something changed on your car since the tune they will be happy to take a look and at least diagnose the problem (if there is one) for you.
^^^ I agree with that... if they screwed up go back to em and see what they have to say about... but 43 degrees of timing is faily high isn't it? standard is like 15 or something like that.. according to the sticker on the bonnet...
Some workshops are really good to there customers - i know if it was Turbotechnics in newcastle they would put the car back on the dyno and double check it and fix it if they can for free.
I hear lots of good storys about advan so i wouldnt be suprised if they do that for you too.
Hey mate,
I had my car tuned by SAS a month or so ago and they did a great job. Good blokes, especially Rodney real helpful, i would recomend them to anyone they are straight talkers...
i wouldnt be to concerned what the guys from one workshop said about another .
your chart looks ok , not great but ok and you said it drove home fine
i think something else is wrong , lots of timing advance will cause detonation and something is f**kign that uo
Yes, even if you approach the ACCC for help, they will always tell you to go back and seek a resolution with the service providors.
Lets not jump the gun with suggestions of involving the ACCC, thats ridiculous
its really not a big deal, 42deg isnt much of a concern
im up near 50deg on my tune and it rawks
if its just knocking in one or two spots
use the pfc faq to help work out where in the maps it is and
then goto advan and ask them to kindly sort it out
every tune knocks differenelty on the street with the owner dirving it compared to being on a dyno in a simulation. happens and just needs a quick touch up once its out of the simulator and in the real world
As Paul said, knock over 60 is something to be concerned about. 120-200 would sound like someone pouring a bucket of gravel under your bonnet.
If you heard abnormal sounds, it's probably knock and should be dealt with. If you didn't hear it, it's probably a bad sensor.
If it IS knock, it could be a caused by a bunch of things, some of which are not the tuner's fault, but most of which probably are. Try some fresh gas before you get too worried.
I wouldn't hesitate to fix it myself, but I like that sort of thing. If you paid someone to do a job, give 'em a crack at fixing it.
Good luck!
Dan
Cost me $3000 for the Power FC, Z32 air-flow meter and the tune which means I paid over $1000 for a dodgy tune. I'll get someone to check out the sensor.
I don't think I'll go back there, they seemed kind of hostile towards me.
I have a friend who highly recommends Powertune in Fairfield, and from what I have read on these forums, they're not so good, but my friend assures me they can do just as good a job as Unique Autosports.
Anyone on here had experiences with them?
Thanks for all the help.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
