there are ones that move across the windscreen from side to side, they usually do the trick :)
nah, doesn't really matter IMO, theres all this fancy testing done on windscreen wipers, but it comes down to preference
ive seen the silicon ones work as well as kmart/supercheap/auto1 ones
Just bought some dual blade replacements from supercheap the other week... awesome... The last ones I used were genuine Nissan from my brother and the dualies are heaps better. They aren't massive things either so they don't look ugly.
Why have one when two is twice the fun!?!
Dude have you tried them?
What I was trying to say is Ive used the BigW ones, only to find that 2 weeks later they get noisey and dont wipe as nice. I made this mistake a few times trying different blade types.
The Nissan ones I have now have wiped the same way when I bought them 6 months ago.
I buy the cheap ones and complain loudly every ime i use them and realise i forgot to change them 3/6/9/12 months ago!
lol my friend got gyped by the pakaging of this $20 wiper "high silicon content" it's clear look like those silicon glue....he put it on, squeaked like mad...laughing my arse off
I think it's really a dried up moulded silicon glue
the best are still bosch spineless oems. The ones that european cars like merc, bmw, volvo, etc, use these days. You know... the flexi kind that has no backbone. Those are wonderful.. but expensive. And you need to modify your assembly to get it to fit. And i love Rain X. I haven't stopped using it since i started years ago.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
