update .
been drifting for over a year now . no issues . fully locked . no noises ever just tyres doing there thing .
Great to hear!
I picked up some shims on the weekend, grabbed a pair of 1.1 and a pair of 1.49, going to shim up my old 32gtst diff and chuck it in the wagoon :happy:
  • 4 weeks later...
shimmed my diff added 0.6mm and now its locked :blink: damn it
up from 1.1 and 0.8 to 1.4 and 1.1, thinking i might pull it apart and go back to original as i dont think this will work for hillclimbs :bunny:
(not sure if its locked 100% but it seems to be ie skips a little on tar.)
Edited by Tiop
I recently Shimmed up my stock diff in my R33 and it works a treat. I increased my overall shim size by 20%. I had a 0.8mm and 1.20mm shims in my center. I replace these with a 1.01mm and a 1.40mm. Seems to be better and is not locked too hard. Tight cornering doesn't make the wheel skip. I think that i could have went a little more shim just to get a bit better result, but seems to be not too bad. I had very little difficulty getting the diff center back into the housing with this amount of shim. :)
I used 50% extra shim on my 200sx and that ended up being locked solid. Also i had a hard time getting the diff center back into the housing.
Based on my experiences now, if i was to do this again i would aim for 25-30% extra shim than the stock.
PS: it is possible to undo the rear mounting bolts on the diff housing, without removing the HICAS motor unit. I just used uni joints on my socket set.
i added 1.49mm shims to both sides, the car is very predictable now, hasnt singled once, mind you it was a locker at the start, but now 6months later is just PERFECT, awesome cheap mod
  • 4 weeks later...
Had my diff guy install the LSD centre out of my 32gtst that I shimmed up, in to the Stageas housing.
Upon opening the diff, discovered it had a 0.8mm on one side and 1.4mm on the other, I replaced these with 1.49mm on both sides.
It's pretty tight, can feel it doing it's thing similar to the 2-way in my skyline but not as harsh.
Very predictable now, the open centre in 2WD mode was just downright scary! The mrs hopes it wears in and stops skipping though hehe
Sorry jet2nv, can't help there but I feel I must report on the results of my shimming..
Now the car was originally open centre but I did have this diff in my 32 before I replaced it with a 2-way. When it was in the 32 it was getting tired and liked to open up.
Now shimmed up and in the wagon, it's awesome! Lots of fun times since installing a week ago, is gradually getting less hrash and I have been punishing it quite severely. Time will tell how the shims wear but hopefully it doesn't start opening up anytime soon.
Excellent bang for buck mod, cost me $200 more than it should but that's because I was swapping the carrier in to a new housing, I felt I should get it set up properly as it's my daily driver.
  • 1 month later...
  • 1 month later...
Just posting up my own experiences as I've done a couple of these diffs now..
My own 33, approx 120,00km, diff would always open wheel. Put in 1x1.49mm + the stock shims, diff would lock on long wide corners but after 2 or so skids when the oil is warm it would again open wheel. Now have 2x1.49mm and have taken 1 stock shim out, diff stays locked a little longer but not much different. Next step is 3x1.49, this would be way over kill for most people but clearly my diff is stuffed.
Another 33 diff around the same age, put in 1x1.49 and it was completely locked. Took out one of the stock shims now the diff locks well and realiably.
  • 5 weeks later...
Does anyone know the outer/inner diameter of the shim so that i can make my own in a lathe?
just buy them from Nissan, like $6 or something, pretty sure the metal would cost more than that if you made them yourself, plus there's a possibility of stuffing it up.
hi guys, instead of making a new thread ill just post in here since its relevant
i purchased a diff some time ago, and it shudders and chirps the inside wheel when turning sharply as one of the posters said earlier, could this indicate it has been shimmed?
the shudder is quite dirty/messy and painfull to deal with.
Sounds more like a stupid basically locked 2 way mech lsd, take it to a diff shop and I am sure they can take some preload out of it, most likely in the form of shims.
Never under stood the point in getting a 2 way lsd that is so tight it chirps around corners.
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
