Defiantly worth the effort. Both wheels lock well under power. Can boost it rite up in tight corners and also both compression lock up under braking and the car remains straight. Feels much, much better then the 2-way LSD in the Passage. When it does let go in a power slide the control is incredible compared to before. A recomended mod for anyone.
Where are you located? Would you do the job for others as I don't have the appropriate tools and my car always one legs and pulls to one side. Obviously some moola will be given. Can post the internals so you don't have to take the entire diff.
Its a very time consuming process and time is something I don't have at the moment. Probably give me a month and PM me and it might be possible. Between this car and work there's nothing left. Sorry.:(
On another note I hit a realy tight corner yesterday going way too fast and got a chirp from the inside wheel so its defiantly working well.
Edited by Bauerpower
saved our ass here in the UAE =) doing it now.
fitted em up, what a bitch to get the center back into the car lol. when i finaly got it in, the splines on the longer half shaft didnt line up in the final section. what a bitch, back out with the center it came, i did actualy line up the splines like you said, might i add for anyone else doing this. once you put ur shims in put both half shafts into the center completly in, then tighten the 2 philips heads, then leave the shafts in. put ur ring gear over the top and rattle that up with the half shafts still in the center. makes it alot easier and no room for error. the first time i was literaly .2mm off the splines being 100percent. and yet it wouldnt go in all together.... peace!
  • 3 weeks later...
Any chance of getting the pics working again really want to give this a go. So say about 3mm would be good for drifting or should i go more like 3.4?
Pretty much depends how screwed your diff is, it'll basically either be almost completely locked or it'll skip around corners and open up under power (worst of both worlds), or it'll be the same.
So just go the biggest you can get in there if you want to lock it, if you want it to be like an LSD just get an LSD.
My local Nissan had them in stock.. did they say they were ex-east? or ex-japan?
3 weeks sounds about right from Japland, everything I've gotten that was ex-east gets sent in an overnight bag so I have it within a couple of days (case in point, ordered a brake booster 1-way valve on Saturday that was ex-east and it arrived yesterday).
  • 1 month later...
just got around to putting mine in,both sides have a shim or 2 with 3 in total so i've got more then 3.6+ mm in there nearing 4 id say (will need to double check invoice to confirm).
so question is how long does it take to bed/ wear in as in getting some shuddering under hard cornering ?
Edited by Dan_J
  • 4 weeks later...
Hello!
I have heard that you can´t shim up a GTST Diff for it´s a viscodiff and not a lsd diff, the shims may take all the power from the diff and the viscodifferential will break? That a shimmed diff will not work in the long run? Is this bullshit or true?
Many people seem very happy with their but boring if it would break!?
Victor
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
