Bubba, has it ever single pegged since shimmed? Also does it still chirp around tight corners?
Nope, no single pegging and it doesn't chirp around tight corners anymore. The only time I can feel it bind up slightly is full lock, reversing out of a parking space.
Even at its' worst (when it was nice and fresh), it was still nothing like trying to park the 32 with a button clutch and 2-way :P
Ive rounded off the righthand side nut in this picture. about to pour petrol over my car and throw a match on it..
Tried smashing on another socket but its so hard to hammer it in the position its in.
Soaked the crap out of it in wd40
Any help would be appreciated.
How do you round off a nut when your using the right size socket? are you sure its not the ratchet slipping? try using a breaker bar and see if it still slips.
Only other thing i can think of, assuming you havnt round it off too badly, buy an impact single hex socket, in the mean time just keep soaking it in WD40 every 30 minutes or so, by the time you get a socket tomorrow it may have made a difference.
Edited by W0rp3D
not sure, the other one came off relatively easy. its rounded quite badly by the looks of it. just got the oxy torch on it, if i have to i'll replace the bush in there.
i doubt theres a more difficult place to round off a nut haha. oh well, extra points!!
mines working well for what its intended for, worn in with in a week and is nice and locked.
now has anyone set the backlash before and do they have part numbers for the backlash shims on the crown wheel?
now my diff does get some hard use now and again and it's started to chirp the rear wheels while driving normaly, straight with good tread tyres etc would this have anything to do with using castrol manual vmx 80 or i figure its also that i have to get backlash set ( as there is some play more then before it was shimmed )?
thanks :pirate:
  • 4 weeks later...
I will be considering doing this as my car really does not like giving me two wheels anymore. Straight line I am ice skating everywhere and it is definitely one wheel spinning... I tried to spin the tires(not for show but just to test the diff) and it is definitely only using one wheel when its spinning.. I don't care for burnouts but if I could tighten up the straight line action, that would be great but from reading here it seems this has more effect when the car is sliding/turning/coming out of turns etc and straight line its still a one wheel... Nissan should have made this diff tighter..
  • 2 months later...
seems the appropriate thread to ask, anyone removed the pinion out of their diffs??
im in the process of removing mine, have removed the large nut (bloody tight) and splined flange off, the centres already out
tapped the pinion end with hammer lightly with the nut on it, but no movement
suggestions?
suggestions?
It's not a proper LSD, just a highly preloaded VLSD, so it basically won't lock up much harder as you accelerate and you are relying upon the preload to do all the locking for you.
  • 7 months later...
allright dudes,iv just finished with a mate his r33 lsd using 1.2 shims its allright but going more after the weekend,tryed getting 1.49s but nissan can only order them in from japland so i settled with 4- 0.8 and 4- 1.2 so im sure we'll get it good and tight soon,had a wee run there but not to happy but we'll give it a weekend first and c, ill keep yous posted
  • 3 months later...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
