A few weeks ago I had my R33 Skyline Diff Shimmed By Ray at RE Customs.
Prior to this my diff would always single spin, so I was looking for a solution to this.
My original thought was to buy either a 1.5 Caz diff or I was also looking into the Nismo 2way.. Both of the mentioned diffs were approx $1500 - $2500 installed so some big dollars.
After speaking to Ray about some possible options he suggested that I could add “shims” to my original single wheeling Nissan Diff to tighten it back up and all for a very affordable price. (Under $400)
The diff can be tightened up using various shims in the diff as per the list bellow:
0.80mm
0.85mm
0.90mm
1.01mm
1.05mm
1.10mm
1.20mm
1.30mm
1.40mm
1.49mm
Based on the selected shim you get a various desired tightness to the diff.
I asked ray to make my diff tight so it was something similar to a 1.5 – 2way Diff.
This was achieved by placing 2 shims additional to the original ones (1 on each side) 1.10mm thick to the diff.
This in turn has come close to locking my diff.
All I can say is its fantastic!!! This is also a very cheap option to fixing a single spinning Diff, and I highly recommend it to those who are sick of a single spinning diff and want a cheap replacement and fix.
I will also add that I am not one for doing things cheap but this does not appear to have any bad affects and is still using the original Nissan gear.
I took the car for a drive on the weekend and through some tight corners
Felt like it was on train tracks. The whole car now feels extremely stable so it has certainly been a viable performance upgrade.
If you’re interested in having this done to your car, speak to Ray at Re Customs and he’ll be able to give you a price and book you in if interested.
Re Customs - 9548 3414
https://www.sau.com.au/forums/topic/164346-fixing-your-single-spinning-diff/
i wonder how it would work on the vspec diff
as i can lock my diff on demand via a switch
so it could be a tight locker on demand
the problem i found with my one is that its a weak lock when it does
hmmm thinking to do...
shims arent a good way to tighten a diff :P
speak to a good reputable diff specialist n he should refuse todo it
i heard this, looked into it, asked for it to be done almost got sworn at... said a good set up tightened lsd shouldnt need to get shimmed ...
so perhaps look into doin a job properly :O
or ...
just weld it up and be done with it ... chirpy chirpy chirpy
From what I've read it lasts about 2 weeks....
shims arent a good way to tighten a diff :D
Really?
Racepace did mine years and years ago now. Before i pulled my car off for the RB26 motor conversion.
The diff did approx 12,000km's (9-10 months) which included lots of burnouts @ the drags as i was racing every 2nd or 3rd week :)
Lots of dyno work, street duties any anything else you car to think of.
Certainly worked ok if you ask me :cheers:
Really?
We dont just shim it, Ash.....:D
We re-machine it, add more clutch plates (most important) and then reshim... they then work really well and last.....
cheers
Ben
We dont just shim it, Ash.....:cheers:
cheers
Ben
Well, there you go.
This is why i pay you a great % of my pay each year :D
cheers
Ben
Is this similar to what you do to the transfer case in the GTR's? I hear from Jack that the re-shimming you did on his, did wonders for his handling on track.
Cheers.
Nick
We dont just shim it, Ash.....:)
cheers
Ben
Ben, any idea on what sort of $ are involved in this? I hate my single spinner! PM if you'd prefer.
BTW - Car is 100% after your work. Top job :)
cheers
Ben
hey ben
would it work the same for the vspec diff?
i have a switch to hard run the vspec pump so i can lock it on demand.
would shimming and changing the clutch in it make it really tight but only when the pump runs?
if so... can you quote a price? (or via pm)
I shimmed my stock VLSD diff which worked well for getting the power down on corner exit BUT in a straight line in first gear the left wheel would always single leg it, second gear would have a slight squeel from usually the left wheel and when the diff was cold second gear would spin up a single wheel as first always would.
I eventually got sick of the lack of traction in first gear and picked up a well priced R32 GTST diff that runs a GTR/GTS4 mech center with nismo 5 bolt axles.
It handles 100% better than the shimmed diff, much much more predicatable. It gets the power down much better/smoother out of corners and no more single spinning through first.
At least now I have an incentive to throw on a set of good tyres. Last time I threw on a set of good toyo's the left rear tyre wore so so much quicker than the right. :)
Shimming the VLSD is good for drift; pretty much for nothing else unless you preload it to the point of the spider gears completely binding. May as well weld it. :)
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
