I'd like to know your compression ratio. I had JE make my pistons for 8.5 to 1. I used 52cc for the combustion camber volume, measured the block height myself, and took the rest of the specs from Tomei. I just noticed that they list their rb24 pistons with a 5.2cc piston crown volume. http://www.tomei-p.co.jp/_2003web-catalogu...ston-specs.html
I believe the Tomei pistons have a 7.9/1 cr. Which seems likely to me since my 8.5/1 pistons have a 8.5cc dome and the Tomei's have a 5.2cc dome. I got my deck clearance by subtracting my rod length plus half the stroke plus the compression height from the block height. This gave me 0.0661" of deck clearance. After over boring to 82mm in my case this effectively increases the combustion chamber lowering the compression ratio. Then the dome brings it back up to the stock 8.5/1.
  • 3 weeks later...
Finally heard back from Ross pistons, below is the data they sent through to me.
Note its all in imperial
________________________________________________________________________
3.465 A dimension (for Ross engineering dept only)
56690 Ross Job Card (number on piston)
7/8/2008 Date Pro/Engineer program was run
TEST CP Program run by
0.326 Deck thickness major front
0.312 Deck thickness major rear
0.173 Minimum thickness under intake valve pocket
0.180 Minimum thickness under exhaust valve pocket
0.200 Minimum thickness at top of flat top / dome / dish
0.367 Minimum thickness of dish to top ring groove
0.251 Intake valve pocket to top ring groove
0.270 Exhaust valve pocket to top ring groove
Lox to oil ring groove
0.153 Skirt
N/A Side relief
Spark Plug notch
Spark Plug slot
0.114 Pin hole to side of pin boss
0.680 Pin engagement in pin bosses (each side)
Edited by murrayis
Update:
My new intake plenum and SARD fuel rail arrived on Tuesday. I got them to make some mounts so I could use the SARD fuel rail on a rb20 plenum. I only have 2 pic's of the plenum atm.
I am Expecting my 6boost Manifold to arrive tonight once Kyle drops it off :P
Also forgot I received my new wastegate in the mail today fresh from the USA
Edited by murrayis
Well thanks to Kyle from 6Boost for dropping my new Exhaust Manifold off at 11:30 last night, I am now able to finish up the engine build as far as bolt on's go. Heres a couple of pics of the manifold, is A highmount T4 Split Pulse.
Cheers
Cameron
  • 3 weeks later...
Cheers
Cameron
any updates on the build?
Well yes there is, yesterday afternoon I was bored and had just got the last bits for the gearbox form nissan so put all that together and put the engine and box back in the car.
I must say I am never doing that again by myself! My poor engine crane paid the toll and has a nice arch in the beam now. I will post some pics a little later after i tidy it up abit.
Cameron
Heres a couple of pics, the engines pretty much just sitting in there at the moment
Still have to finish off porting the intake manifold ot match the head its half done, then just a matter off mounting the gearbox up 100% running all the oil and water lines, and get a tailshaft.
Can anyone recommend a place around the western subs in brisbane who make tailshafts?
Edited by murrayis
  • 1 month later...
Ok so I am planning on getting the engine started this weekend. I just finished the wiring tonight and decided to turnthe key and jsut crank it over to move some oil around a couple of things i noticed.
1) Theres a hissing sound coming from the dip stick that slowly tappers down after you stop cranking like pressure build up and slowly leaking out
2) oil pressure guage on the dash doesnt move but the light does fliker a little bit
Is this normal for a fresh built engine? Or shold I be looking into it before I try to start it all?
Indeed it is, Not bad for a 1 week turn around from kyle. The only thing I had to do to the manifold was TIG on a 45 degree bend for the wastegate :)
you might want to be careful there, i remember someone else posting about doing something similar and it caused boost control issues
  • 3 weeks later...
Well the hot day it is here in Brisbane we decided to crank the engine over and get her running. After a bit aof head scratching of why the injectors weren't firing we jiggled the ecu wiring harness and all of a sudden they worked.
A couple of small things I have to sort out before it goes off the be tuned.
1) Retension the timing belt as its a little to tight and sitting a bit far back on the gears for our liking
2) Finish interncooler piping
3) make it run on 6 cyl instead of 5 :wacko:
Well I spent a good part of today checkeing all the electrical connections and cables in my car to do with the coils and injectors it all turned out fine, but came across the number 3 injector wasn;t firing where in previous tests it was.
Isolated the injector and disconnected all the coils so no chance of blowing myself up, i took the injector out to see if it was blocked which it wasnt put 12v directly onto it... nothing gave it a quick tap with a screwdriver and tried 12v again and ot mu surprise it clicked gave it 10 mins and tried it again and it clicked. So I installed it back into the fuel rail adjusted the tension on the timing belt while I was in there, also found the steel plate behind the crank sproket was rubbing on the oil pump so pressed that a bit flatter so it cleared the pump and put all the timing belt and balancer back in.
Fired her up after a nice BANG! that my poor puppy is still trying to recover from, still have to adjust the idle a tad as its still at 2000rpm. I recorded a lil vid of the sound of it sitting at 2k idling
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
