There is high temp sheathing that will cover the line you run for the wastegate and from there you can always take the rubber hose (for length) down to your local hydraulic hose guy and get them to make one up. Even if they needs to use a reducign bush for the M5 conneciton
its going to be tight to find something that will fit in there.
I would take out the nipples and braze some brass tube onto them that is about 40mm long and then have a olive/sleeve collet fitting connecting to a braided line. that way you can screw the original fittings in place and leave them in place and screw the lines in situ.
hope this makes sense. just take the gate with the fittings to pirtek/enzed and tell them what you want to do ;) probably cost a bit but it will work and withstand 100's of degrees.
cheers!
Once I get the car back I dont think I will have any choice but take the gate off and see what Enzed and Pirtek can do.
Roy, Yea gate cap is billet.
I spoke to NYTSKY who has the same gate he said he just used normal silicon but I assume his gate is mounted a tad further away from the main heat source.
AD4M, Thanks for that any links to suppliers who stock it?
Quick Update - Found the oil leak.... Appears the oil filter isnt done up quite enough so when the car gets dropped off this arvo I'll fix that up, Then I just have to get a replacement CAS and see if that resolves the problem with it not running.
Cameron.
  • 4 months later...
  • 2 months later...
No real updates, been busy with work and other unexpected things.
I have over christmas installed a new Haltech ECU to replace the Adaptronic, I have just finished wiring up all the sensors etc and all that is remaining is to make a alloy bracket for the map sensor.
I also am trying to find a decent Catch can with -8 / -10 an fittings so I can plum in the breathers.
Once I find a some spare weekends I'll stick it on a trailer and take it to the dyno to start fresh with the tune.
Cheers
Cameron
Cheers
Cameron
There is nothing decent readily available on the market, you will need to make one. -10 fittings are the way to go :D
I am looking to make something similar to what RIPS have done for their customers, fitting it where the battery tray is.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
