Evening all,
No new updates, Paul's picking up the 9ltr sump tomorrow and from talking to Paul on Tuesday he mentioned I may have the engine back by the end of next week!
Now I am still waiting on the Hypertune Intake and Throttle Body... Hope to hear Monday that it will also ship next week!
Looking at pulling the box out and having it rebuilt, if anyone knows a good gearbox place in Brisbane for GTR box's let me know.
Also looking at running the car on the Green stuff but it's a big commitment at $2.50ltr
Cheers
In about 2 weeks ill be able to show you my brothers rb24 build. Mechanics are arseing around a fair bit. Should have been on the dyno last week........
Used a mixture of tomei parts and rb26. Ported head (tomei cams to come after a few thousand kms) garrett gt3040r turbo, nistune ecu. Made well over 220rwkw with the worst tune ever (stock r31 ecu and SAFC2 lol)
He is hoping for over 300rwkw after the cams go in.
Oh and its in a black HR31 coupe. :P
Howdy All,
Thought I would post some teasers to how it's coming along.
Firstly, Apologies for the quality of the pics.
We had a slight Hold up with there being no girdle with the new block.....But that arrived in Newcastle as of 12:25pm today :P so all systems are back on track & Just had word my Hypertune Plenum should be shipping today....
Edited by murrayis
What lift cams are you running and compression ratio to have to relieve the pistons? Was that a custom order?
Tomei 270 9.25mm Lift, Comp Ratio is in the High 8's and pistons are custom order from ROSS Pistons in the USA.
what kind of plenum did you use from hypertune, and how much pm me if you dont want to disclose on thread, reason i ask as i am looking at getting a plenum and chasing info and options lookf forward to the dyno and another stroked rb20 i can associate with
cheers yt
Hmmmm... twins?
Hmm Correct... But what twins?
motor looks sexy, will be interesting to see what the dyno yields at the end of it.... :P
Indeed it will be we are looking for a very reliable 400rwkw - Well I am at least :)
cheers yt
Plenum and 90mm Throttle body came in around the $2000 as was custom made by Pete and the boys.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
