This is most likely one of the best looking cars I have ever seen. Light as a feather, 380Hp L6 engine and a body to die for. Last think heard 2nd hand ones were going for about 50,000 UK Pounds.
the sagaris are very a nice car there is also a 490HP V8 one made for track use only. if they could be complied i would try and get one here in a second
got some better pics around here of another TVR motorsport Customers which is painted a bit more friendlier than the black one
Edited by Whiplash
Looks nice and agressive, thats why i like it, that corvette looks like a girls car :) Best looking car that i know of in existence is definitely an aston martin, either the db9 or the 2008 dbs... mmmm, theres one around the corner in that P1 workshop i was drooling over yesterday
Don't think I'm a fan of the looks..
much sexier?
You couldnt honestly choose a new Vette over a TVR with that level of sexyness
Have a closer look at the build quality and interior if you need more time... then have a listen
http://youtube.com/watch?v=qUcWHnpNOVE
Edited by ctjet
That car has to be one of the ugliest things to ever make it's way into production.
What the hell is going on in the back. Who the hell thought exhaust pipes going out sideways was a good idea. It's like something a little kid thought up.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
