Why would you skimp on something as important as engine oil?
x2
fully synthetic please
nulon hi-tech fast flowing has been going pretty well in mine but its not a true fully synthetic (only class 3, barely fully syn)
will be changing to Gulf Western S6000 Sougi next week, its hard to find but its as good as Motul 300v Chrono apparently but only $60-70 for 5 litres
and its nothing like the cheapo $12/bottle stuff supercheap sell either
worth looking for really
ive posted mods a few pages back,
got pod, fmic, boosted slightly more then stock, dump off the turbo, gutted cat and hks exhaust, thats about it.
i dont drive her too too hard but i still give her a push here and there....
Nice one. Pretty surprising you haven't got it retuned or anything. I just filled up today. 410km and 54L (13.1L/100km). Not brilliant.. I really want to get a wideband AFR meter and see if I can lean it out a bit more for normal driving. Hardly gunned it at all during the last tank.
I know I know what you mean. I have 3 cars and the other 2 uses Royal Purple which is not cheap. Although I use cheaper mineral oil for the Stag, I change it more often. Still that's no excuse! :blink:
Well now that one car is going, I thought I'd use a better oil on the Stag so hence the change.
my S2 gets about 320k's per tank, maybe alittle more if i am highway driving. main reason is that i have a gtr-s, front mount, exhaust,stock boost, stock maps (nistune fitted).
once i get the board tuned i'll find the economy will go up dramactley.
Thats pretty low for a series 2, especially with those mods... Hope the nistune helps dramitcally
...I also would like to say, i really hope to see under 10l per 100k after my nistune install, hi-flow panel filter and turbo back exhuast....
How has fuel economy gone since the nistune? I have very similar mods and am tempted if it's going to reduce my fuel bill dramatically.
Edited by webng
626kms 78.8L (not impressive, but it was fun :( )
As an aside, I would not recommend running so low on fuel in an M35, I accelerated moderately up a minor incline, only to have the engine drop out on me for a split second due to a lack of fuel picked up by the pump lol.
  • 5 months later...
G'day,
Just picked up a std S2 RS4V and drove it back from sydney to melbourne.
From Goulburn Caltex to Caltex Avenel 99% highway driving at 110kmph we used near on exactly 60lts of 95RON for 557km (odo actualy read 570kms due to smaller than std tyres fitted).
However a drive (correct tyre sizes) around town and highway, pretty much a 50/50 split saw a drop in 100kms of economy ie 470kms for again pretty much 60ltrs of 95Ron Caltex.
Deduce from that that maybe a drive 100% round town means 370km per 60ltrs - "Crikey"!
And also light comes on at close to 60lts used - Are these things 65lt or 68lt tanks?
Thought I'd add my readings.
"Safe Boating",
Mike.
675 km's for 75 L y'day
roof rack, windows down, air con on, no pussy footing
gonna fit a fuelstar fuel catalyst soon too so will get back to you on that when I do
The available evidence would seem to indicate these are a con. Did you fit one and has there been a long term difference in consumption?
G'day,
"Safe Boating",
Mike.
grab yourself a new oxygen sensor and it should help out a bit, the sensors only have a limited lifespan and rarely get replaced in japland
i also run 95 in my stagea due to the exorbitant price of 98 in tas but it does lack a bit of power compared with 98 and i get slightly less fuel consumption with it too (the ecu will run more timing on 98 = better fuel economy)
no one makes an aftermarket o2 sensor for the s2 stageas (rb25 neo same as r34 gtt) so its either stock nissan one for about $250 or get one for a s1, r33 gts-25t, n15 sss pulsar and cut and re-crimp the wiring using your old plug
Pipster11 thanks for the comments.
I have read all the comments on fuel economy in this and other threads, "helpfull info - thanks everyone" (O2 sensor change duly noted).
The 570kms that I got, all be it highway run, seems to be quite good when compared - so I am more than happy with it. Had a bit of weight (4 x 19x8.5 with tyres) in the back aswell.
It's daily route will be 85% highway 15% town - hoping for at least 500ks a tank normal driving.
Cheers.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
