  • Replies 100
Hahah yeah i think dose is a pretty funny word lol but how it is related to flutter i do not know....
Why not make a 'dose pipe'?
I think that turbo cars that dont make any noise are just plain boring. >_<
*awaits flamage*
I think "dose pipe" is as funny as hell but it's an open forum and I'm sick of seeing new users hammered for asking questions or having different views to the majority :)
I dare you to join the minority group and see what happens to YOU :sorcerer:
Dose pipes, metal intake pipes, flutter.. it all means the same thing --- SSoooOTuTuTuTuTU!!
Who cares that you get defected for it, if you drive a skyline and a cop makes you pop your bonnet you get done for any stupid thing they feel like pickin on anyway...Mehhh!
PS-don't need to get off the topic and add other bs, relate your post to my original topic thats on page ONE!
.......................................Suuuukutukutukutututu....................
Translated as:
Suck you too, k, you too, k, you too, you too, you too............................... :/
I have one of those apexi metal intake pipes, I can confirm that the intake noise is louder than a plastic one. It is also more high pitched.
I tried blocking the BOV off, and yes full hektic flutter was abundant. But I wa not a fan of the overfueling, stalling and whatnot.
if it's being detrimental to my car, then the care factor is f*cking huge.
Couldn't think of anything worse that to intentially create mechanical problems to my car
What mechanical problems does a metal intake pipe create for your car?
he is talking about leaving the bov blocked off and lettting it surge its ass off every time the throttle body closes
it's arguable that letting the compressor surge its ass off every time causes damage, i agree
do a survey of 100 vl turbos with captain insano surge and ask them how many have done turbo rebuilds
care factor. soo! soo! soOOkutukutukutututu...
:ermm:
So are you going to post anything of interest or a bunch of letters each time?
Pointless threads get sent to the wasteland, and this isnt far from it now
I run a 6 inch straight metal pipe off the turbo with a small filter on the end, I beleive it should "by theory" suck in more cool air than my last setup which was a pod filter fitted up near where the standard airbox was mounted. The piping to the pod was mostly steel apart from 1 90degree bend which was rubber. Im still yet to test to see if the straight pipe is more responsive because my clutch is slipping so I don't want to drive it on boost till I get a new one.
And yes it makes it sound exactly like a vl turbo, its "doses" are insanely loud, too loud sometimes when you just want to drive normally.
Oh and I run after market computer so no afm and blocked bov - hence the very loud flutters.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
