  • 4 weeks later...
Swapped over to HC+ for a couple of sprint days now.
Obviously you have to sell your kidneys to buy a set of these. The last few sets of A1RM
were only giving me 2 days days before backing plate. The HC+ give 5 track days till
the backing plate. They also have far more initial bite, don't cover all the rotor slots with material
and have a greater fade point.
A1RM are great for anyone doing 4-5 track days a year. If you are looking for something more I can
recommend HC+.
  • 3 weeks later...
Hi, trying to find a good pad for my 300 awkw R34 GTR (non-vspec). Standard brembo calipers, am planning to get the DBA 4000 XS (slotted/drilled) rotors all round.
It will be used 99.9% for street driving. I am looking for
1. Minimal noise (MOST IMPORTANT)
2. Minimal rotor wear
3. Cold performance
4. Minimal dust
5. Cheap
In that order.
Based on this, should I get the QFM HPX? Any alternative? 1-2 ppl have reported that they are squealy, which would be a deal-breaker for me. Not properly bedded in?
And which store sells these? I am based in Melbourne.
Oh, and when's a good time to replace pads? If it goes to the backing plate I am guessing that will be bad for the rotor. Mine are at 30% all round.
Cheers.
3. Cold performance
4. Minimal dust
5. Cheap
In that order.
In that order I'd recommend a European performance brand called Remsa, which is what we supply to a few specialist VW/Audi/Porsche workshops. The HPX isn't a noisy pad normally, but unfortunately opposed pistons calipers (like your Brembos) are notorious for noise regardless of pad selection, and we know the Remsa's work very very well in opposed pistons calipers, like Porsche, who's drivers definitely wouldn't accept noise. The Remsa's come standard with a soft shim on the back that the QFM's do not.
Remsa to suit Brembo are $125 for the front, and $105 for the rear. Shipping is free when you order front and rear pads together, or else $8 per axle set individually.
If the order was dust, rotor wear, noise, then I'd recommend HPX, but if your emphasis is on noise, you definitely won't go wrong with the Remsa, which as a bonus are also rated to 650 degrees (100 degrees better than Bendix Ultimate or HPX).
Regards,
Greg
Regards,
Greg
Cool, sound good. Tried to find out more info on them but on the Remsa website they don't seem to go into detail differentiating different brake pads, and couldn't find my car on their site either. Do they just make 1 level of brake pad?
Thanks.
Hi mate,
Yep, there's only one level of Remsa (unless you stumble across the US varients, in which there's a couple, but we stock the European version). Just a little bit more back ground on Remsa, they're a subsidiary of the TRW Group, and in fact they're the manufacturer of TRW (Lucas) pads, but their brand pads ARE NOT the same as TRW pads. They're miles less dusty for starters...
Any questions at all feel free to give us a bell.
Regards,
Greg
  • 1 month later...
looking for some pads to go with my new rotors, what do people recommend?
Car is daily driven, R34 GTR pretty much stock. 99% of its driving will be just daily road duties.
pads will go with my new DBA4000XS (pics attached)
Thanks in advance
Noy
  • 4 weeks later...
Finally fitted my QFM A1RM pads that I got from gslrallysport, when I removed the Bendix Ultimates they where half worn and had some cracking going on, after fitting the A1RMs and bedding them in I find they are a big improvement on the Ultimates, the only squelling I got was during the bedding in but after about 10 80kph to 20kph runs they were nice and quiet.
Inital view on them is they are much better in feel and grip on the street, Im doing Wakie on the 5th of March so will see how they go there.
Mark
What Break pads would you guys recommend for a R34 GT-T not a track car street only but occasionally having a led foot :/
QFM HPX, Bendix Ultimate equivalent but low dust and rotor wear, $79 per set front or rear. A1RM would be a bit extreme if you weren't doing track work.
Hey guys looking for some pads for my R32 Gtr track car. Still running the standard sumitomos, was originally running DS2500's which I found to be very good after warming them up. However the last track day I went to the pads were shot and all I could find were bendix ultimates, which faded terribly after 4 laps. Are there any other good racing pads I could try out? Also, is there money to be saved buying pads online from the States etc.? What are some other lesser known brands that have good track performance?
I loved project mu HC+ on the standard sumis with caliper spacers. Trying out blue stuff atm, they are growing on me.
HC+ have fantastic initial bite, while the blue stuff seem to drip you through the front window later in the pedal.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
