  • 4 weeks later...
Swapped over to HC+ for a couple of sprint days now.
Obviously you have to sell your kidneys to buy a set of these. The last few sets of A1RM
were only giving me 2 days days before backing plate. The HC+ give 5 track days till
the backing plate. They also have far more initial bite, don't cover all the rotor slots with material
and have a greater fade point.
A1RM are great for anyone doing 4-5 track days a year. If you are looking for something more I can
recommend HC+.
  • 3 weeks later...
Hi, trying to find a good pad for my 300 awkw R34 GTR (non-vspec). Standard brembo calipers, am planning to get the DBA 4000 XS (slotted/drilled) rotors all round.
It will be used 99.9% for street driving. I am looking for
1. Minimal noise (MOST IMPORTANT)
2. Minimal rotor wear
3. Cold performance
4. Minimal dust
5. Cheap
In that order.
Based on this, should I get the QFM HPX? Any alternative? 1-2 ppl have reported that they are squealy, which would be a deal-breaker for me. Not properly bedded in?
And which store sells these? I am based in Melbourne.
Oh, and when's a good time to replace pads? If it goes to the backing plate I am guessing that will be bad for the rotor. Mine are at 30% all round.
Cheers.
3. Cold performance
4. Minimal dust
5. Cheap
In that order.
In that order I'd recommend a European performance brand called Remsa, which is what we supply to a few specialist VW/Audi/Porsche workshops. The HPX isn't a noisy pad normally, but unfortunately opposed pistons calipers (like your Brembos) are notorious for noise regardless of pad selection, and we know the Remsa's work very very well in opposed pistons calipers, like Porsche, who's drivers definitely wouldn't accept noise. The Remsa's come standard with a soft shim on the back that the QFM's do not.
Remsa to suit Brembo are $125 for the front, and $105 for the rear. Shipping is free when you order front and rear pads together, or else $8 per axle set individually.
If the order was dust, rotor wear, noise, then I'd recommend HPX, but if your emphasis is on noise, you definitely won't go wrong with the Remsa, which as a bonus are also rated to 650 degrees (100 degrees better than Bendix Ultimate or HPX).
Regards,
Greg
Regards,
Greg
Cool, sound good. Tried to find out more info on them but on the Remsa website they don't seem to go into detail differentiating different brake pads, and couldn't find my car on their site either. Do they just make 1 level of brake pad?
Thanks.
Hi mate,
Yep, there's only one level of Remsa (unless you stumble across the US varients, in which there's a couple, but we stock the European version). Just a little bit more back ground on Remsa, they're a subsidiary of the TRW Group, and in fact they're the manufacturer of TRW (Lucas) pads, but their brand pads ARE NOT the same as TRW pads. They're miles less dusty for starters...
Any questions at all feel free to give us a bell.
Regards,
Greg
  • 1 month later...
looking for some pads to go with my new rotors, what do people recommend?
Car is daily driven, R34 GTR pretty much stock. 99% of its driving will be just daily road duties.
pads will go with my new DBA4000XS (pics attached)
Thanks in advance
Noy
  • 4 weeks later...
Finally fitted my QFM A1RM pads that I got from gslrallysport, when I removed the Bendix Ultimates they where half worn and had some cracking going on, after fitting the A1RMs and bedding them in I find they are a big improvement on the Ultimates, the only squelling I got was during the bedding in but after about 10 80kph to 20kph runs they were nice and quiet.
Inital view on them is they are much better in feel and grip on the street, Im doing Wakie on the 5th of March so will see how they go there.
Mark
What Break pads would you guys recommend for a R34 GT-T not a track car street only but occasionally having a led foot :/
QFM HPX, Bendix Ultimate equivalent but low dust and rotor wear, $79 per set front or rear. A1RM would be a bit extreme if you weren't doing track work.
Hey guys looking for some pads for my R32 Gtr track car. Still running the standard sumitomos, was originally running DS2500's which I found to be very good after warming them up. However the last track day I went to the pads were shot and all I could find were bendix ultimates, which faded terribly after 4 laps. Are there any other good racing pads I could try out? Also, is there money to be saved buying pads online from the States etc.? What are some other lesser known brands that have good track performance?
I loved project mu HC+ on the standard sumis with caliper spacers. Trying out blue stuff atm, they are growing on me.
HC+ have fantastic initial bite, while the blue stuff seem to drip you through the front window later in the pedal.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
