I will chime in here.
I used Intima SR for a track day. and they sucked a big proverbial dick. I literally crumbled them on the track.
QFM a1rm did 3 track days in one set of pads and they stopped my boat much quicker.
So for me the intima pads are "garbage"
The ss would be on par with the hpx, which I now also have and they drive absolutely great for normal street duties.
That is extremely interesting, I myself went from A1RM to Intima SR and found them great.. 2x of my mates with EVOs also went from A1RM to Intima SR and found them better.
Another track wh0re I go with on his 180SX went fro A1RM to Intima SR and found them great too albeit he runs R33 Brembos on his 180SX.
You may have had a bad batch or so.
  • 3 weeks later...
Help me pick some pads :)
mostly reading about qfm hpx, a1rm and intima ss and sr's. These are the main ones talked about in this thread and google. Unless you guys have or know of something better for me?
the hpx are 500* and the ss are 400* Both don't chew rotors, but are far from the 700* of a1rm and sr's
I'm looking for a semi crossover pad. Something that will perform well on the street 60-80k roads with plenty of braking up and down hills for 30-60 minutes at a time, but wont chew rotors in traffic.
The rear pads will have to be used for both track and street. fronts will be changed to SRT's for the track thanks to Luke. Will be on t3 rotors f+r
All good! Joe just hooked me up with some rear remsa pads, seem to be perfect for what i want. 650* with lower rotor wear and a lower cold starting degree.
Remsa is an awesome pad from completely cold... but are dusty af.
  • Like 1
Correcto, I had remsa all round once apon a time. Not a bad pad at all, except for the dust. Dusted more than the vdub.
Honestly if you want a 50/50 pad, then you gotta choose between a1rm or SR's. Or drive with dedicated street and swap over to track pads.
  • Like 1
thats the plan ;) needed something decent for the street but not as agressive as track pads.
Will be changing the front to srt pads for the track
edit: update. Just spoke to GSL and he mentioned not to change pads without skimming rotors.
I had Intima SS on my R34 GTT (IN1170M-SS and IN1220M-SS) and melted them on a hilly drive near Black Spur, no good.
Upgraded to Remsa (0348.02 and 0365.02) and they are going great on the street and around Sandown with DBA T3's.
Hard to beat for value, you just have to be prepared to put up with the dust, they are very dusty.
  • Like 1
How about pads for D2/KSport/Attakd kits?
Are these options even available? I know I want to upgrade something before I attempt to stop my barge on a race track, and the pads that came with the kit (green ones) I can induce brake fade on the street in about four corners and have had brake pad splatter all over the place.
Clearly not ideal lol.
Been Recommended Pagid RS29's, but they are in the region of $700 for a set.
What else is comparable?
  • Like 1
I used to swap between QFM HPX (street) and A1RM (track) and didn't have any issues. Changed to Winmax W5 for track use and that resulted in some massive brake shudder because the HPX pad would just layer on top of the Winmax material. Once I had the rotors skimmed it was all good again but I won't be swapping pads again without skimming.
As far as I am aware, track pads dont put much "layer" on the disk due to their aggressive characteristics. So technically when you put track pads on after a different pad it should clean the surface for you.
Maybe you over heated the rotor
Other way around, the issue was with the street pad layering on top of the track material. Swap back to track pads and do some hard braking and it mostly cleaned it up then swap back to street pads and not long after I would get shudder again.
Didn't have the same problem with HPX and A1RM I guess because they're a "similar" compound.
Now running Ferodo DS2500 pads full time.
And if you utilised your track pads as "rotor cleaners" then you wouldnt have the transition issue.
Whilst keeping the track pads cold, everytime you brake it will clean the rotor bit by bit. Continue to do this at street driving level, dont enter bed brake in mode as that will heat up the pads too much and start transferring onto the rotor.
This way you could transition brake pads.
Has anyone heard of RoadHouse brake pads before, or better yet has anyone actually used them?
I decided i'd try some Remsa pads so ordered some through a reputable trader. I was very disapointed to see these RoadHouse pads had been delivered instead.
They came with a letter stating; "In Europe, Remsa pads are sold under the RoadHouse brand... In Australia RoadHouse pads are supplied if there is no stock of the Remsa pad at the time."
I can't find much about the RoadHouse pads on the interwebs, so hoping someone has experience with them.
Considering sending these back and ordering some Intima / QFM pads from one of the forum sponsers instead.
Remsa are standard pads. They are made in Spain (also know as Roadhouse in various markets) and are ECR90 rated, which means +/- OEM performance. of course I am prepared to be called on this information by GaRkson, as they know best. Granted my knowledge of the product only comes from selling the **** for 3 years while I worked for Autostop/ASL and the various training days we had with Remsa.
They are Remsas. Isn't that what you wanted?
Part numbers?
My Remsas are 0348.02 and 0365.02, from GSL RallySport. They are rated 650 degrees C from memory so definitely not OEM/standard style pads, also much better than the Intima SS that I had prior. Very dusty though.
Edited by V28VX37
Well if RoadHouse = Remsa, it looks like I got what I paid for so gotta be happy with that, still would of been nice to be notified prior to purchasing that they were out of stock of the Remsas and Brand replacement will occur.
I'll be putting these in anyway but would love to hear if someone has used RoadHouse branded brakes in the skyline.
Part numbers?
Part numbers: 0234802 and 0236502.
The letter from the supplier also says "The RoadHouse part numbers are exactly the same, save for the '2' at the beginning"
Going by all the reveiws on here i see that they are dusty but also a street pad rated to 650 C, so a little higher than Bendix Ultimates / Intima SS / etc.
  • Like 1
Yep sounds like a match, good to know!
From what I've read they're supposed to sit somewhere between QFM HPX and A1RM. I wanted something street friendly that is still ok on the track, without chewing up the rotors. Also A1RM's apparently can be squealy, the Remsas are quiet, just really dusty.
Here's the description:
http://gslrallysport.com/au/348-02-remsa-brake-pads.html
http://gslrallysport.com/au/365-02-remsa-brake-pads.html
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
