I have used all.
Why do you want to step up?
Going to the track?
SR is more aggressive than ss.
FP3 doesn't bite aswell cold as the SR. But handles heat and Wear better. I recommend this for track.
If I were you and only using for the street, ss would be my choice.
If you really want to step up then go SR. Just remember that Cold braking will be slightly affected
Thanks for the speedy replies!
Looking more to improve the feel and performance I have now with the SS pads, with the hope of throwing in the odd track day in the future
Having the SR pads on the back too, I'd like to match or better the pads on the front performance wise. The FP3 sounds like it's more track suited if it's not as good cold, so I'll just grab the SR's, cheers guys
What Bill said. I've had both SS and SR, wouldn't do the SS again but the SR are great. They were excellent at Sandown with new RDA rotors too.
I have some squeal on the street under light pedal pressure but otherwise can't fault them.
Talk to Johnny for a deal :)
  • 4 weeks later...
Had the Intima SR's on front now for a few weeks, they are really good.
No noise so far, minimal dust and decent amount of bite. Good pedal modulation under heavy braking
Street use only at this stage
I have Intima SR's as well on new RDA slotted rotors. Bedding in procedure was done correctly, but mine squeal like a pig when light breaking (i'm talking car park below 15km/h speeds)
On the road and under normal to heavy breaking they are noise free
On 12/04/2017 at 9:58 AM, niZmO_Man said:
I have Intima SR on the front on my wagon, it's quiet. Bit dusty though and overkill for my daily wagon use.
If it's a daily, should go SS :)
add a bit of copper grease between the caliper piston and brake pad - it helps :)
Bought Intima SR's from Johnny a while ago, they held up pretty good at Sandown, once hot they stopped awesome just felt I had to apply quite a bit of pedal pressure. Appart from the low speed sqeal I can't complain and Johnny was awesome to deal with
  • Like 1
  • 3 weeks later...
Power Stop in the US sent me a set of their "Track Day" pads.  Yeah, they're called "Track Day".   They're partners with Bondourant Driving School here and used on Vettes.
They're something like $65 and I think they're very cheap in comparison to what else is out there.  At New Jersey Motorsports Park I only had 30 minutes of track time due to an ABS pump failure but they performed well enough with ATE Type 200 fluid.  NJMP's Thunderbolt circuit has a two higher speed straights with braking zones from 120-130 to 60 MPH'ish.  The pads felt like they had no issues with the job.
After getting home and removing the pads, I think they wore down 50% or so.  I'd have to measure thickness but I'm not so sure they would have held up to a 2-day weekend and 120+ minutes of lapping.
Edited by Nihilation
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
