I have done a little bit of aero work on the r33 gtst.
- I use an ebay BeeR knockoff wing in carbon fibre (coating only, i'm sure). it was just under 800 shipped from China, reasonably quickly. Quality was good for the price, no issues with it. At 100k+, you feel the front of the car getting lighter with more downforce coming into effect on the rear. I put it on the lower-angle setting, as the higher one was too much drag...so yes, definitely do something, although the only benchmark I have is the stock gtst wing, and the r33 gtr stock wing. There were 2 widths available, and mine was the smaller - it runs right to the edge of the rear quarters/body outline...although looks wider in the pic.
- I also use an ebay carbon fibre Top-secret style diffuser, with a few custom additions. it seemed to give a little more planted feel to the rear when cornering at speed, but I now have a full-length custom flat undertray, which when combined with the diffuser, IS noticeable, making the diffuser much more worthwhile/effective. The car really gets low at high speeds, and when you hit a bump in the rod, lifting the car and breaking the low-pressure area, yes it's noticeable, and occasionally a little hairy with the difference in feeling of car-control.
- other items include bonnet vents, canards, front quarter vents, custom front splitter....all of which make positive differences of varying degrees. The front undertray and bonnet ducts made a massive difference to cooling, with it holding a very stable 70-80 degrees at all times other than long idle. I believe I am keeping an impartial view to it - for example, I experimented with a divider panel leading air out in front of the rear wheels (r35 gtr feature small ones) but found it made the rear unstable and skittish, so binned them.
Couple of old pics - there have been a few little changes since these.
  • Like 1
Also, have a look at Performance Forums, for postings going back a few years now by Nelsonian (or some name like that with numbers on the end), talking about considering and then actually doing "cheap eBay aero" on his fast Falcon Turbo. IIRC there is a lot of very good learning in there. The upshot is that what Hardsteppa said is true. The eBay aerofoils can be fine.
Ultimately, all this learning already exists anyway - you just have to dive down the rabbithole to chase it.  There was massive work done by NACA on aerofoil profiles and there have been numerous studies of how each of these perform when used upside down (ie, on a car), with lots and lots of "if you're doing A, choose aerofoil B. If you're doing X, choose aerofoil Y" type advice available.  Just have to search it out, and maybe buy the occasional actual paper book.
Maybe an inbetween is an Origin GT wing ?   at least its well made
I had what ended up being an ebay type CF wing that I was sold second hand as an Origin GT wing snap at 230kmph
Previous to that had an actual Orgin GT wing and structurally superior to the ebay spec one
re: aero.......... yes alot of info and rule of thumb can be found but usually takes lots and lots of rabbit hole searching as mentioned above
Edited by bcozican
On 5/11/2019 at 10:29 AM, GeeDog said:
Old topic, but thought I'd continue this rather than creating a new thread.
We have an R33 GTST, setup as a dedicated track car - BC ER coilovers, Whiteline swaybars, some adjustable suspension arms, 245 & 275 R88r's, 8 port front brakes, 320 or so RWKW from RB25/30 on E85, 2 way diff, etc.
We've recently started working on aero improvements, and have built a removable front end with a plywood splitter (has to be removable to get on & off the transporter). Rear is currently an aftermarket fibreglass GTR style wing - don't know who made it as it was on the car when we bought it. The blade is now stuffed - started with a split along the trailing side, which we glued & taped. After a stint at The Bend yesterday, the leading edge is now also split - son reckons he could see the centre of the blade (in the mirror) almost touching the bootlid near the end of the straight. Top speed reached was around 240kph, and lap times in the 2:16's (according to Harry's) on a very cold, drying track, so it is a fairly serious setup.
The new front splitter has also created an imbalance between front & rear, so its time to upgrade the rear wing.
We had a go at 3D printing wing sections, that we planned to assemble using aluminium tubes, but had too much trouble with warping. Have given that idea away for now.
We don't just want to replace the existing blade - we are after a wider wing, with decent endplates, that sits higher than the GTR wing. Ideally we'd like to keep within Time Attack Clubsprint rules, so not outside the body of the car in any plane.
We can buy a China Ebay wing, but the impression is that they are more for show than go. Shipped cost is around $900 - $1000, which is too much for something that may not actually work. Most of them aren't wide enough anyway.
I know we can buy a Topstage wing, but cost is $2650, plus freight, and I don't think that includes uprights. I have no doubt these are a good product, but a bit beyond the budget at the moment.
I've seen the Bee-R style wings on Ebay, but I have no idea if they are functional or not, and what the quality is like.
Does anyone know of any in-between options available in Oz? Has anyone used an Ebay wing, and have any thoughts to share? Any other sellers in Australia other than Topstage? Any input is appreciated. We are in SA, so a local supplier would be good.
2:16 and 240km/h at 'The bend' is impressive, hopefully see you out there one day
Unfortunately that wasn't me driving, but my son. I'm a couple of seconds slower at Malalla, haven't driven The Bend yet. We will be entering a Supersprint there in June - on the west circuit though.
Thanks for the input guys - I will do some more digging (or get junior on to it). GTSBoy - we used a NACA wing profile when we went down the 3D printing path.
On Sunday we bought a length of 25 x 25mm aluminium square section and a can of expanding foam, cut a matching hole in each end of the existing blade, pushed the ali through, then filled the blade with foam (after using the 3D printed sections to stop it exploding. We will 3D print a gurney flap for it, and have race-taped the leading & trailing edges to stop air getting in. It is much stronger than ever. Hopefully it will work for the June event at least. Worst case someone behind will wear an exploding wing blade.
I doubt that the ebay type have had any serious testing so if you know what you need and could draw a design maybe a surf board maker could build you one.
Good idea - that thought hadn't crossed my mind.
13 hours ago, GTSBoy said:
Should have put a handful of confetti & glitter in there
That thought also didn't cross my mind - bugga
  • 3 weeks later...
Just quoting you so you get a notification for this post, but what issues were you having with warping with the 3d printing?
Was it warping while printing or when you took it off?
I've had issues with my printer warping, but it all came down to a bit of tuning on the printer and overall print setup.
I would not consider 3d printed parts on a traditional 3d printer suitable for "high stress" though. It's amazing how the different plastics deform and fail!
We were using Pet-G filament (for the first time) to gain extra strength. We printed 200mm long sections of wing, which were designed to be a firm fit over the existing wing. The idea was that the existing wing would hold the new sections together, and provide the mounting points. The end of the sections that were printed first (ie on the bed) were warped when we removed them from the bed, so they didn't join to the next section properly. I believe this is common with Pet-G. The attached pic shows 2 pieces with the "warped" ends together. The 2 outer faces of these 2 pieces are perfect, and parallel with each other.
Other than that it seemed like it would work fine - they were very light & very strong. Even had an inbuilt gurney flap.
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
