I have done a little bit of aero work on the r33 gtst.
- I use an ebay BeeR knockoff wing in carbon fibre (coating only, i'm sure). it was just under 800 shipped from China, reasonably quickly. Quality was good for the price, no issues with it. At 100k+, you feel the front of the car getting lighter with more downforce coming into effect on the rear. I put it on the lower-angle setting, as the higher one was too much drag...so yes, definitely do something, although the only benchmark I have is the stock gtst wing, and the r33 gtr stock wing. There were 2 widths available, and mine was the smaller - it runs right to the edge of the rear quarters/body outline...although looks wider in the pic.
- I also use an ebay carbon fibre Top-secret style diffuser, with a few custom additions. it seemed to give a little more planted feel to the rear when cornering at speed, but I now have a full-length custom flat undertray, which when combined with the diffuser, IS noticeable, making the diffuser much more worthwhile/effective. The car really gets low at high speeds, and when you hit a bump in the rod, lifting the car and breaking the low-pressure area, yes it's noticeable, and occasionally a little hairy with the difference in feeling of car-control.
- other items include bonnet vents, canards, front quarter vents, custom front splitter....all of which make positive differences of varying degrees. The front undertray and bonnet ducts made a massive difference to cooling, with it holding a very stable 70-80 degrees at all times other than long idle. I believe I am keeping an impartial view to it - for example, I experimented with a divider panel leading air out in front of the rear wheels (r35 gtr feature small ones) but found it made the rear unstable and skittish, so binned them.
Couple of old pics - there have been a few little changes since these.
  • Like 1
Also, have a look at Performance Forums, for postings going back a few years now by Nelsonian (or some name like that with numbers on the end), talking about considering and then actually doing "cheap eBay aero" on his fast Falcon Turbo. IIRC there is a lot of very good learning in there. The upshot is that what Hardsteppa said is true. The eBay aerofoils can be fine.
Ultimately, all this learning already exists anyway - you just have to dive down the rabbithole to chase it.  There was massive work done by NACA on aerofoil profiles and there have been numerous studies of how each of these perform when used upside down (ie, on a car), with lots and lots of "if you're doing A, choose aerofoil B. If you're doing X, choose aerofoil Y" type advice available.  Just have to search it out, and maybe buy the occasional actual paper book.
Maybe an inbetween is an Origin GT wing ?   at least its well made
I had what ended up being an ebay type CF wing that I was sold second hand as an Origin GT wing snap at 230kmph
Previous to that had an actual Orgin GT wing and structurally superior to the ebay spec one
re: aero.......... yes alot of info and rule of thumb can be found but usually takes lots and lots of rabbit hole searching as mentioned above
Edited by bcozican
On 5/11/2019 at 10:29 AM, GeeDog said:
Old topic, but thought I'd continue this rather than creating a new thread.
We have an R33 GTST, setup as a dedicated track car - BC ER coilovers, Whiteline swaybars, some adjustable suspension arms, 245 & 275 R88r's, 8 port front brakes, 320 or so RWKW from RB25/30 on E85, 2 way diff, etc.
We've recently started working on aero improvements, and have built a removable front end with a plywood splitter (has to be removable to get on & off the transporter). Rear is currently an aftermarket fibreglass GTR style wing - don't know who made it as it was on the car when we bought it. The blade is now stuffed - started with a split along the trailing side, which we glued & taped. After a stint at The Bend yesterday, the leading edge is now also split - son reckons he could see the centre of the blade (in the mirror) almost touching the bootlid near the end of the straight. Top speed reached was around 240kph, and lap times in the 2:16's (according to Harry's) on a very cold, drying track, so it is a fairly serious setup.
The new front splitter has also created an imbalance between front & rear, so its time to upgrade the rear wing.
We had a go at 3D printing wing sections, that we planned to assemble using aluminium tubes, but had too much trouble with warping. Have given that idea away for now.
We don't just want to replace the existing blade - we are after a wider wing, with decent endplates, that sits higher than the GTR wing. Ideally we'd like to keep within Time Attack Clubsprint rules, so not outside the body of the car in any plane.
We can buy a China Ebay wing, but the impression is that they are more for show than go. Shipped cost is around $900 - $1000, which is too much for something that may not actually work. Most of them aren't wide enough anyway.
I know we can buy a Topstage wing, but cost is $2650, plus freight, and I don't think that includes uprights. I have no doubt these are a good product, but a bit beyond the budget at the moment.
I've seen the Bee-R style wings on Ebay, but I have no idea if they are functional or not, and what the quality is like.
Does anyone know of any in-between options available in Oz? Has anyone used an Ebay wing, and have any thoughts to share? Any other sellers in Australia other than Topstage? Any input is appreciated. We are in SA, so a local supplier would be good.
2:16 and 240km/h at 'The bend' is impressive, hopefully see you out there one day
Unfortunately that wasn't me driving, but my son. I'm a couple of seconds slower at Malalla, haven't driven The Bend yet. We will be entering a Supersprint there in June - on the west circuit though.
Thanks for the input guys - I will do some more digging (or get junior on to it). GTSBoy - we used a NACA wing profile when we went down the 3D printing path.
On Sunday we bought a length of 25 x 25mm aluminium square section and a can of expanding foam, cut a matching hole in each end of the existing blade, pushed the ali through, then filled the blade with foam (after using the 3D printed sections to stop it exploding. We will 3D print a gurney flap for it, and have race-taped the leading & trailing edges to stop air getting in. It is much stronger than ever. Hopefully it will work for the June event at least. Worst case someone behind will wear an exploding wing blade.
I doubt that the ebay type have had any serious testing so if you know what you need and could draw a design maybe a surf board maker could build you one.
Good idea - that thought hadn't crossed my mind.
13 hours ago, GTSBoy said:
Should have put a handful of confetti & glitter in there
That thought also didn't cross my mind - bugga
  • 3 weeks later...
Just quoting you so you get a notification for this post, but what issues were you having with warping with the 3d printing?
Was it warping while printing or when you took it off?
I've had issues with my printer warping, but it all came down to a bit of tuning on the printer and overall print setup.
I would not consider 3d printed parts on a traditional 3d printer suitable for "high stress" though. It's amazing how the different plastics deform and fail!
We were using Pet-G filament (for the first time) to gain extra strength. We printed 200mm long sections of wing, which were designed to be a firm fit over the existing wing. The idea was that the existing wing would hold the new sections together, and provide the mounting points. The end of the sections that were printed first (ie on the bed) were warped when we removed them from the bed, so they didn't join to the next section properly. I believe this is common with Pet-G. The attached pic shows 2 pieces with the "warped" ends together. The 2 outer faces of these 2 pieces are perfect, and parallel with each other.
Other than that it seemed like it would work fine - they were very light & very strong. Even had an inbuilt gurney flap.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
