  • Replies 233
quick question..
How hot would this pipe get? Or will the pipe remain a bit cooler than stock piping?
and what did you mean by : 'sucky closed under boost' lol..
thanks
Edited by siddr20
Hey ppls,
I've checked about the logos, and unfortunately I have to order over $10,000 USD in order to have different logos. Just quietly, I'm not ordering anywhere near that!
When can you tell? Well, about 1 bar with the stock airbox and the thing will suck closed. The hotter the engine bay gets, the less boost required to suck closed. How can you tell? Well, you come up on boost and then suddenly you loose power. HPI saw it in their Project 34 and several others have seen it too.
Also the standard pipe is pretty ordinary with air flow, so the new pipe is much smoother on the inside.
BASS OUT
PS. I will get all final details of the buy together and start this running now.
Okay,
Group buy in motion.
I'll close the group buy in 2 weeks from today, so Monday week.
Payments will be as follows.
$135 per Inlet pipe. $20 per postage as it's going to be over 1kg per piece when packed. As always when sending, if you are in a remote area then the freight will be more and I will let you know and we will work it out. This has only happened twice though,
$110 for the pair of Radiator hoses also. Freight will be the same $20 for the Radiator Pipes. I might be able to combine these, but it will depend on the boxes I can get.
So it's $155 total for the inlet pipe and $135 radiator pipe.
Each pipe or hose will be in it's own card-board box and wrapped appropriately for postage.
Estimated time frame.
The supplier has told me 2-3 weeks for manufacture.
Will be about 2 weeks in freight.
Another week for me to box them up and send them out.
Okay, colours.
We can get Black, Red or Blue.
AT THIS STAGE R32 GTS-T ARE NOT BEING OFFERED UNTIL I CAN GET A STANDARD R32 GTS-T PIPE TO TEST... PLEASE LET ME KNOW IF YOU HAVE ONE OF THESE AVAILABLE.
All pipes can use the standard clamps.
Payment Details
Peter N Blythe
Bank of Melbourne, Westpac
BSB: 733382
ACC: 586817
Amount $varies
Reference : Username
Once you have paid please send me an e-mail to [email protected]
The e-mail should contain the following information.
First Name, Surname
St Address
Suburb, State, postcode
Mobile Number
Copy of deposit reference.
The package goes normal freight and so the delivery address should be somewhere that you will be during the day over the next 2-4 days depending on your location. I have had them arrive overnight, I have also had them arrive 6-7 days later (Perth and Darwin)
So, you have 2 weeks to get the payments through and leave the rest to me.
Many of you have dealt with me in the past, but for those who haven't, check my trader ratings. I'm legit.
So guys lets get it happening, I'm pretty keen on getting these myself!!!! :)
BASS OUT
Edited by Bass Junky
Bass, silly question (not doubting you in anyway and still interested) is that $30 postage for each one from hong kong to us? or are they coming over in a batch and then $30 from your house to mine?
I'm pretty tight on cash, and 30 from melbourne to sydney for 1kg seems a bit dear with normal aust post?
No harm intended, just wondering
Edited by MANWHORE
Hi Manwhore.
That's a fair question so I'll explain.
The $30 is the inside Australia freight cost.
I buy custom made boxes to the correct size for the application which cost about $5 each. The pipes will be over 1kg in weight, so the Aust Post component must be worked out on cubic volume.
I reckon the box is going to have to be about 400mm x 200mm x 200mm which which postcode 3175 to lets say 2100 = $9.65 which means that I've stuffed up the calculations terribly.
In actual fact, these things should comfortably fit into a 3kg Postage satchel!
Therefore, postage will be $20 everyone!
Sorry for the mistake! Please change the postage cost to $20. This will cover the satchel and all the stuffing around.
CHEERS PETE! (Thanks Manwhore. You have actually made my job a lot easier!)
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
