i need a clutch installed on my R32 gts-t asap... have the clutch in possession but wont be free until 3pm onwards. who can do the job?
or
does anybody know anyone in my area(dandenong, lyndhurst, narre warren) that can install it for a decent price?
cheers :)
Sucks to be you and I Josh.
My clutch is due too. $800 supplied and fitted using dedicated Honda care and parts HAHAHA. But yes, pending on it to burn right out. For now I still manage to get uphill.
Slippage FTW!
haha mel :) i got my Exedy 5puk cushion button clutch for 220 he he... and its costing me a further 350 to be installed including machined flywheel and new thrust bearing..
and you think yours was slipping! 5th went first, then 3rd, then the rest... 1st in high revs goes off still lol thankgod i had it to go up the "semi hills" on stud rd :)
ive got a mate who has once again saved my ass...
DNGRUS, thanks but ive got it done :D are you able to do clutches?
Edited by 180sxdrifterj
the more you load a slipping clutch - the more damage you do to the flywheel
if your clutch is shagged and slipping baby it around, unless u want a new flywheel too
it will last a bit of you baby it around
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
