I found a new one!! My series 2 had a little mis-fortune and needed a new Throttle position sensor. These are very different between the series 1 and 2 with the 2 having a pair of wiring loom entries and the series 1 only having a single wiring harness. It pays to check before ordering from Japan!!
Dave :sly:
  • 3 months later...
Cool britto I think that ALSD was an expensive (and therefore uncommon) option on type-M's, lucky you :D
Are you absolutely sure it's got dual airbags?? Like above the glovebox it has a rectangular outline and says SRS Airbag?? Cos I've never heard of any R33 other than a full-blown SII that had 2 airbags.
As for the driving lights, I'm pretty sure Series 1s have them, just not the same type as Series II, SII driving lights are round.
Yeah its got dual airbags, previous owner bought it with all the safety extra's. And it says SRS airbag on the rectangle. Yeah i was real lucky. As for the driving lights, i was told that they dont work on s1 as they weren't hooked up. Not sure how reliable my source is though.
As for the front rectangular indicator/foglight, there are 2 different types in the Series 1.  Some have nothing in there and it is simply a white lense, whereas others have a foglamp there.
Make that 3 types, another option on series 1 was dual fog/driving lamps in the lower front 'type M' bar, in the area that is normally covered by black plastic mesh. Only ever seen 1 like this though.
Sure its just not a dash from a series 2? cuz there is no such thing as an r33 made in 1993 with dual airbags
There is such a thing as a 93 s1 with dual airbags, coz its sitting in my garage. The steering wheel (air bag) looks different to s2 and so does the passenger side air bag. They are also factory standard. Since your all so skeptical i've posted an image of my interior.
  • Like 1
trust me mate...it has dual airbags...ive sat in this car many-a-times to know that there are definately two airbags.
Actually I read recently on an options list for 93-95 GTSt's that passenger airbag was an option. The fact that Britto's is the only one anyone's ever seen just shows how much Japanese skyline drivers cared about their girlfriends ;)
Looking at that photo tho that looks very much like a series II dash, tho maybe they just used same (similar) dash in S1s which took second bag option?
  • Like 1
A guy from Nissan confirmed that it was optioned up with the second airbag, and i guess it uses the similar design of the s2.
  • 3 weeks later...
Mechanically Series 2 started at the beginning of 1995, though many will claim it was 1996. This is true if you judge a vehicle by cosmetics. 1995 saw the introduction of the updated ECU and ignition system. I’m not sure about an updated turbo though.
is it worth buying the s2 then.... i got my s1 for 15800 completely stock from an importer.. its 93 model.... i figured if i was going to do it up then why bother with the s2 if ill be changing the goodies anyway.... just my oppinion though.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
